motorvated |
Member ![]() ![]() Group: Members Posts: 282 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains ![]() |
I'm not expecting much from a 1.8 but seems like it is lacking power under load at higher rpm. Top speed is about 80 mph, and not enough power to get it into 5th gear. Engine is tuned, distributor is cleaned, timed and has full advance, point gap is to spec, valves adjusted, new air cleaner, fuel filter, plugs, points, condenser, coil, wires, cap, and fuel pump. New fuel cell, so no tank sock issues. Throttle is opening all the way, and fuel pressure is to spec under load. Injectors cleaned with good spray pattern, cold start valve not leaking. New vacuum lines. EGR, decel valve, and crankcase breather all still hooked up to intake snorkel. Tried two different AFM's, and although one seems a little stronger, it's still weak at the top end. Even went through the AFM static and dynamic mixture adjustment procedure on one of them to set it at " just lean". Richening it doesn't help. The only thing I haven't yet checked is compression, but engine idles smoothly, burns no significant oil, and pulls cleanly to about 4,500 rpm. Don't yet have an AFR to confirm mixture, but planning on getting one soon.
Running out of ideas, anyone have any suggestions? Should I disconnect the EGR, decel, and route the crankcase breather to a catch bottle to rule these things out as potential contributors to the problem? Obviously, I need to do a compression check. I'm running the cat at elevations ranging from 4,500-7,500 feet above sea level, so that will have so effect on performance, but I expect more than I'm currently getting. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,896 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
You found fuel in the oil ....not good,wonder how long it had been run like that,its called bore washing and plays havoc with the piston ring lands over time resulting in piston wear and compression loss in extreme cases the rings usually break.
As mentioned a compression test is in order then you will really know,I would snug up those valve clearances also a DD mentioned,good luck. |
Lo-Fi Version | Time is now: 31st July 2025 - 11:43 PM |
