> WET SANDBLASTING A 914
Curbandgutter
post Aug 10 2016, 04:45 PM
Well I'm getting ready to wet sand blast (WSB) my project car and I wanted some input form those who have done it and or have some direct or indirect experience with it. I purchased a wet sand blasting kit from a company back east. I tried a sample piece and was thoroughly impressed. I was able to remove the paint down to bare metal on the underside floor in under 5 minutes. It was incredibly fast. The primer that I am using is an epoxy primer by SPI. I spoke with the manufacturer and they said to steer away from using a rust convertor as they can be very tricky to remove from seams. They also said to just blast it and spray it the next day. The flash rust will not be a problem. What has been your experience
Vapor_locked
post Aug 10 2016, 07:11 PM
I'd second & listen to what Jeff has said, and what Sir Andy has pointed out! Good luck with the project!
Curbandgutter   WET SANDBLASTING A 914   Aug 10 2016, 04:45 PM
Tom_T   I know that the guy at my shop wont sandblast at a...   Aug 10 2016, 04:54 PM
Curbandgutter   I'm WET blasting therefore there shouldn't...   Aug 10 2016, 05:01 PM
SirAndy   Don't do it! You'll have sand coming o...   Aug 10 2016, 06:29 PM
Jeff Hail   I'm old school BUT for a full strip "dust...   Aug 10 2016, 06:39 PM
Vapor_locked   I'd second & listen to what Jeff has said,...   Aug 10 2016, 07:11 PM
charliew   I would use a rust converter especially if the col...   Aug 10 2016, 08:19 PM
jcd914   Mark Whitesel (Mikey914/914Rubber) did this to one...   Aug 10 2016, 09:48 PM
jmitro   my car was media blasted (non WSB) for $1100 ...   Aug 10 2016, 10:29 PM
scotty b   I own the wet system. ( Dustless blasting ) I hav...   Aug 11 2016, 06:46 AM
Vacca Rabite   High humidity makes the whole system uselss as f...   Aug 11 2016, 11:32 AM
mepstein   I own the wet system. ( Dustless blasting ) I ha...   Aug 11 2016, 01:24 PM
mbseto   Need a nitrogen atmosphere paint booth.   Aug 11 2016, 12:19 PM
Jeff Hail   Need a nitrogen atmosphere paint booth. Not re...   Aug 11 2016, 12:57 PM
worn   Need a nitrogen atmosphere paint booth. Not r...   Aug 11 2016, 02:44 PM
Vysoc   I agree humidity is a monster, come to Florida its...   Aug 11 2016, 01:38 PM
Curbandgutter   Thanks guys. After talking to paint manufacturer,...   Aug 11 2016, 06:47 PM
914forme   :popcorn: good luck   Aug 11 2016, 07:30 PM
mbseto   [quote name='Jeff Hail' post='2383699' date='Aug ...   Aug 12 2016, 08:14 AM
Mark Henry   Actually this looks interesting and you can get ch...   Aug 12 2016, 09:15 AM
mepstein   Remember, like scotty b has said in past threads, ...   Aug 12 2016, 10:09 AM
ssuperflyoldguy   Remember, like scotty b has said in past threads,...   Aug 12 2016, 10:45 AM
scotty b   Remember, like scotty b has said in past threads,...   Aug 12 2016, 01:51 PM
Mark Henry   Well I was intrigued so I went and bought an el ch...   Aug 25 2016, 08:19 PM
Mark Henry   So this was the result of my quick test shot. As ...   Aug 26 2016, 08:13 AM
mepstein   So this was the result of my quick test shot. As...   Aug 26 2016, 08:42 AM
Cairo94507   Mark just probably wanted to blast some rust and t...   Aug 26 2016, 08:48 AM
Mark Henry   Why not just use a regular sand blaster on a ste...   Aug 26 2016, 11:13 AM
gandalf_025   Body shop I sent my car to had it Soda Blasted and...   Aug 26 2016, 09:21 AM
Curbandgutter   Well I got busy wet blasting the 914. Ran out of ...   Aug 29 2016, 02:00 PM
Vacca Rabite   Well I got busy wet blasting the 914. Ran out of...   Aug 30 2016, 08:07 AM
Curbandgutter   [quote name='Curbandgutter' post='2391754' date='...   Aug 30 2016, 08:53 AM
bulitt   Mark- I have used this Krud Kutter stuff after con...   Aug 30 2016, 11:20 AM
bulitt   Mark- I have used this Krud Kutter stuff after con...   Aug 30 2016, 11:28 AM
Curbandgutter   If you do a search on flash rust you're going ...   Aug 30 2016, 02:40 PM
- Lo-Fi Version Time is now: 4th July 2025 - 06:06 PM
