> ALT light troubleshooting. FIXED, Specifically, what makes it come on?
malcolm2
post Jul 31 2016, 06:03 AM
I noticed the last time i parked that the red "G" light had come on slightly. Got in yesterday and it was on bright and the volt meter was at 10.5. Revving the engine did not help either.
I checked the belt tension and decided to tighten it.
Took a 20 minute drive to Nashville and all was well. At the last stop i saw the dim G light again. Then bright for a while. Then out.
What is the prognosis? I have about 20k miles on the alt wire harness and gel battery. Maybe 10k on the rebuilt alt.
malcolm2
post Aug 11 2016, 07:33 PM
3.5 hours and the rebuilt alt is in. No heat exchanger yet, but i had to start it and see.
Key on,
light on,
key to start,
engine starts,
light goes off,
VDO volt meter moves to 13.
Did not run long. Pretty loud with only 1/2 an exhaust.
Done for the night. Ready to drive this weekend.
(IMG:style_emoticons/default/beerchug.gif) to all that chimed in.
malcolm2   ALT light troubleshooting. FIXED   Jul 31 2016, 06:03 AM
Rand   If you're lucky, it's just dirty contacts ...   Jul 31 2016, 10:51 AM
jim_hoyland   This write covers your question and a lot more: h...   Jul 31 2016, 05:32 PM
jim_hoyland   Another good source is Ratwell's: http://www....   Jul 31 2016, 06:06 PM
malcolm2   Another good source is Ratwell's: http://www...   Aug 1 2016, 08:16 AM
malcolm2   [quote name='jim_hoyland' post='2378911' date='Ju...   Aug 2 2016, 07:41 PM
Spoke   I took the plastic cover off of the board behind ...   Aug 3 2016, 06:38 AM
malcolm2   You can test the alternator by removing the VR a...   Aug 3 2016, 07:01 AM
malcolm2   I also checked the Ohms on the VR per the Ratwell ...   Aug 3 2016, 07:04 AM
Spoke   site says: I GOT: •D+ and DF - 0.3 o...   Aug 3 2016, 10:59 AM
malcolm2   [quote name='malcolm2' post='2379860' date='Aug 3...   Aug 3 2016, 01:53 PM
Spoke   You can test the alternator by removing the VR ...   Aug 3 2016, 10:54 AM
malcolm2   You can test the alternator by removing the VR...   Aug 3 2016, 03:10 PM
malcolm2   I did "search" but rarely found a fix. ...   Jul 31 2016, 07:35 PM
Rand   .....   Aug 2 2016, 09:18 PM
malcolm2   I started her today and after a 10 minute warm u...   Aug 2 2016, 09:22 PM
jim_hoyland   This type of problem has always baffled me too; :...   Jul 31 2016, 08:01 PM
bretth   I haven't had the opportunity to dive into my ...   Jul 31 2016, 10:30 PM
catsltd   Mine did the same as your car.Even the 10.5 volt t...   Aug 1 2016, 08:24 AM
Rand   [edited] I saw that too late. :D You're on it.   Aug 2 2016, 09:28 PM
malcolm2   just checking around to purchase a VR, if needed. ...   Aug 3 2016, 11:14 AM
Spoke   Definitely a good sign. It shows the alternator ca...   Aug 3 2016, 04:45 PM
malcolm2   Definitely a good sign. It shows the alternator c...   Aug 3 2016, 04:58 PM
Spoke   The alternator seems to be at least providing volt...   Aug 4 2016, 09:36 AM
malcolm2   The alternator seems to be at least providing vol...   Aug 4 2016, 09:57 AM
Spoke   The alternator seems to be at least providing vo...   Aug 5 2016, 10:09 AM
worn   I noticed the last time i parked that the red ...   Aug 4 2016, 01:20 PM
malcolm2   Try: [url=http://www.pelicanparts.com/techarticl...   Aug 4 2016, 01:55 PM
worn   Try: [url=http://www.pelicanparts.com/techartic...   Aug 4 2016, 05:35 PM
Spoke   Paragraph 2 is what SPOKE suggested and it gave m...   Aug 5 2016, 10:23 AM
malcolm2   How many times have you repeated the DF/D+ short...   Aug 5 2016, 11:42 AM
Spoke   [quote name='Spoke' post='2380889' date='Aug 5 20...   Aug 5 2016, 02:14 PM
malcolm2   Heading home now. FedEx said they are should be th...   Aug 5 2016, 02:56 PM
malcolm2   well damn, I did the D+/DF short test once more an...   Aug 5 2016, 03:36 PM
malcolm2   Cancel that post.... 4th time I got the light to ...   Aug 5 2016, 03:49 PM
ClayPerrine   Sounds like something in the alternator wiring. I ...   Aug 6 2016, 06:50 AM
Spoke   Sounds like something in the alternator wiring. I...   Aug 6 2016, 09:18 AM
malcolm2   Sounds like something in the alternator wiring. I...   Aug 6 2016, 11:27 AM
malcolm2   The bitch is out. I rang out all 4 wires and they ...   Aug 8 2016, 07:49 PM
Spoke   I have tested diodes on an alternator but you have...   Aug 9 2016, 12:19 PM
malcolm2   I took mine and 1 other unknown spare for testing ...   Aug 9 2016, 02:25 PM
malcolm2   Rebuilder said the brushes were worn down enough t...   Aug 10 2016, 12:57 PM
malcolm2   3.5 hours and the rebuilt alt is in. No heat excha...   Aug 11 2016, 07:33 PM
Spoke   Nice! :beer2:   Aug 12 2016, 07:15 PM
- Lo-Fi Version Time is now: 3rd September 2025 - 09:47 PM
