> Steering Wheel Wobble at Speed, I'm out of ideas
LotusJoe
post May 16 2013, 06:44 PM
Europa Twink Driver
I am experiencing wheel wobble at freeway speeds. At around 60 the steering wheel wobbles, but you can drive through it. At about 70 it quits. I assumed it was a tire out of balance. So I rotated the the backs to the front. No difference. I then put a different set of tires on the car. Same issue. Then I switched yet another set of tires from the race car. Same issue. Unless I have 4 sets of tires that are out of balance I'm a bit perplexed. The entire front end has completely new everything. Any thoughts on where to check? (IMG:style_emoticons/default/confused24.gif)
New:
FreeMotion roller bearings on the arms
Bilstein Sport Shocks
Turbo Tie rods
New tie rod ends
New lower ball joints
New upper polly bushings
New wheel bearings
New Rotors
New Calipers
New bushings on the sway bar
(Everything is new)
tradisrad
post Aug 12 2016, 02:36 PM
I had this issue before and I had the tire shop balance the front wheels on the car. Only one shop in my area did this. 5 point tires in redwood city.
Good luck
LotusJoe   Steering Wheel Wobble at Speed   May 16 2013, 06:44 PM
JawjaPorsche   I assume you had the front end aligned after putti...   May 16 2013, 06:49 PM
LotusJoe   I assume you had the front end aligned after putt...   May 16 2013, 06:50 PM
JawjaPorsche   I assume you had the front end aligned after put...   May 16 2013, 06:53 PM
914itis   Get all four balanced by a good tire shop and you ...   May 16 2013, 06:54 PM
Elliot Cannon   Adjust the front wheel bearings. Sounds like they...   May 16 2013, 06:56 PM
Bartlett 914   Adjust the front wheel bearings. Sounds like the...   May 16 2013, 07:34 PM
6freak   Adjust the front wheel bearings. Sounds like the...   May 17 2013, 08:47 AM
76-914   :agree:   May 16 2013, 07:10 PM
Jeffs9146   Letting the car sit to long on your tires, maybe y...   May 16 2013, 07:28 PM
r_towle   Steering rack?   May 16 2013, 07:58 PM
worn   I am experiencing wheel wobble at freeway speeds....   May 16 2013, 09:01 PM
tomeric914   Tighten the wheel bearings and then tighten them a...   May 16 2013, 09:55 PM
Garold Shaffer   Tighten the wheel bearings and then tighten them ...   May 16 2013, 10:01 PM
Cap'n Krusty   I am experiencing wheel wobble at freeway speeds....   May 16 2013, 11:10 PM
L-Jet914   I am having the same issues as Lotus. Now off to ...   May 17 2013, 12:02 AM
GeorgeRud   Kind of a long shot, but you could also consider h...   May 17 2013, 07:08 AM
Steve Snyder   You might also want to ensure the four Allen bolts...   May 17 2013, 08:35 AM
brant   not a solution to your problem but I don't lik...   May 17 2013, 08:37 AM
LotusJoe   Thanks for all the input. I will attempt to answer...   May 17 2013, 12:21 PM
Sandy Teener   Thanks for all the input. I will attempt to answe...   Sep 1 2015, 09:09 PM
r_towle   I have seen more than a few steering racks that ha...   May 17 2013, 02:17 PM
bulitt   I would go through every nut and bolt and make sur...   May 17 2013, 10:30 PM
Dasnowman   Hubcentric rim rings ? Had a couple of vehicles w...   May 18 2013, 01:57 AM
billh1963   What was the solution? Inquiring minds want to kno...   Oct 18 2013, 01:57 PM
tadink   hmmm, I've got the same thing, I thought it wa...   Oct 18 2013, 06:32 PM
rhodyguy   have you ever had your wheels checked for 'tru...   Oct 19 2013, 07:47 AM
hedfurst   You also might want to be sure the nuts that secur...   Oct 19 2013, 08:06 AM
Porschef   I lost the last bit of shimmy when I changed out t...   Oct 19 2013, 08:53 PM
jkuehn   Anyone figure this one out because i am the exact ...   Nov 6 2013, 09:12 PM
914Mels   You might have to look around for a shop that can ...   Nov 7 2013, 02:36 PM
mzapisek   I've been experiencing similar problems. Car ...   Aug 12 2016, 12:51 PM
914_teener   What is your suspension set up?   Aug 12 2016, 01:30 PM
mzapisek   From previous owners info: "19mm thru body ...   Aug 12 2016, 02:23 PM
914_teener   So a 5 lug set up with a 19 mm through body bar an...   Aug 12 2016, 02:33 PM
tradisrad   I had this issue before and I had the tire shop ba...   Aug 12 2016, 02:36 PM
ssuperflyoldguy   Old school: car on ground- grab wheels 3&9 and...   Aug 12 2016, 06:58 PM
Localboy808   I agree with other who have said to check every nu...   Aug 12 2016, 07:43 PM
colingreene   I put Lotus Joes car on a lift and checked all of ...   Aug 12 2016, 08:33 PM
Sandy Teener   I put Lotus Joes car on a lift and checked all of...   Aug 12 2016, 10:53 PM
Sandy Teener   I put Lotus Joes car on a lift and checked all of...   Aug 12 2016, 10:54 PM
mzapisek   OK underneath the car and everything looks good - ...   Aug 13 2016, 08:10 AM
rhodyguy   If you drive over a set of railroad tracks, or lik...   Aug 13 2016, 12:49 PM
mzapisek   Disconnected one drop link as others have advised....   Aug 13 2016, 06:25 PM
- Lo-Fi Version Time is now: 9th June 2026 - 04:11 AM
