> Dropped a valve seat...what's the verdict?
billh1963
post Aug 15 2016, 04:29 PM
Car Hoarder!
Way back in August 2013 I went to start my 914 and heard a funky noise. I immediately shut it down. Using my limited mechanical knowledge (and a tremendous amount of luck) I postulated that I had dropped a valve seat.
Three years later I decide it's time to get this 914 back on the road. Pulled the heads and, sure enough, a dropped valve seat. Prior to the issue the car was running good...no smoking, seemingly good oil pressure, etc.
I'm hoping I can get by with just rebuilding the head (if possible). Anyone see anything that would cause me to deviate from this plan of action?
billh1963   Dropped a valve seat...what's the verdict?   Aug 15 2016, 04:29 PM
Mike D.   I did the same thing back in 2000. Had the head re...   Aug 15 2016, 04:36 PM
ConeDodger   I see at least two and maybe three cracks in that ...   Aug 15 2016, 04:46 PM
billh1963   I see at least two and maybe three cracks in that...   Aug 15 2016, 04:54 PM
porschetub   I see at least two and maybe three cracks in that...   Aug 15 2016, 05:05 PM
porschetub   Oh dear the head is scrap ,not worth the repair co...   Aug 15 2016, 05:01 PM
billh1963   Oh dear the head is scrap ,not worth the repair c...   Aug 15 2016, 05:08 PM
r_towle   Depending upon your finances I would suggest you b...   Aug 15 2016, 06:04 PM
76-914   Is that piston cracked above the indentation?   Aug 15 2016, 06:13 PM
billh1963   Is that piston cracked above the indentation? I...   Aug 15 2016, 06:27 PM
HAM Inc   The seat drop repair alone is not so bad, as far a...   Aug 15 2016, 06:43 PM
billh1963   The seat drop repair alone is not so bad, as far ...   Aug 15 2016, 06:45 PM
ConeDodger   The seat drop repair alone is not so bad, as far ...   Aug 15 2016, 07:47 PM
HAM Inc   The seat drop repair alone is not so bad, as far...   Aug 16 2016, 09:29 AM
Philip W.   Looks like you will be building that 2056 --- you ...   Aug 15 2016, 08:08 PM
Toast   I've had a valve seat embedded in a head befor...   Aug 15 2016, 11:40 PM
cwpeden   And don't use head gaskets. I used them for th...   Aug 16 2016, 12:40 AM
- Lo-Fi Version Time is now: 4th March 2026 - 10:23 AM
