| billh1963 |
Aug 15 2016, 04:29 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,427 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Way back in August 2013 I went to start my 914 and heard a funky noise. I immediately shut it down. Using my limited mechanical knowledge (and a tremendous amount of luck) I postulated that I had dropped a valve seat.
Three years later I decide it's time to get this 914 back on the road. Pulled the heads and, sure enough, a dropped valve seat. Prior to the issue the car was running good...no smoking, seemingly good oil pressure, etc. I'm hoping I can get by with just rebuilding the head (if possible). Anyone see anything that would cause me to deviate from this plan of action? |
| Mike D. |
Aug 15 2016, 04:36 PM
OK, It runs now, and pretty good too! ![]() ![]() ![]() Group: Members Posts: 1,457 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None
I did the same thing back in 2000. Had the head rebuilt, didn't touch anything else. Put it back together ran fine for years after. Sold the motor in another car when I did my conversion in '06. Never heard from new owner so I guess it was just fine for him too.
Depends on if the engine was running fine before? |
billh1963 Dropped a valve seat...what's the verdict? Aug 15 2016, 04:29 PM
ConeDodger I see at least two and maybe three cracks in that ... Aug 15 2016, 04:46 PM
billh1963
I see at least two and maybe three cracks in that... Aug 15 2016, 04:54 PM
porschetub
I see at least two and maybe three cracks in that... Aug 15 2016, 05:05 PM
porschetub Oh dear the head is scrap ,not worth the repair co... Aug 15 2016, 05:01 PM
billh1963
Oh dear the head is scrap ,not worth the repair c... Aug 15 2016, 05:08 PM
r_towle Depending upon your finances I would suggest you b... Aug 15 2016, 06:04 PM
76-914 Is that piston cracked above the indentation? Aug 15 2016, 06:13 PM
billh1963
I... Aug 15 2016, 06:27 PM
HAM Inc The seat drop repair alone is not so bad, as far a... Aug 15 2016, 06:43 PM
billh1963
The seat drop repair alone is not so bad, as far ... Aug 15 2016, 06:45 PM
ConeDodger
The seat drop repair alone is not so bad, as far ... Aug 15 2016, 07:47 PM
HAM Inc
The seat drop repair alone is not so bad, as far... Aug 16 2016, 09:29 AM
Philip W. Looks like you will be building that 2056 --- you ... Aug 15 2016, 08:08 PM
Toast I've had a valve seat embedded in a head befor... Aug 15 2016, 11:40 PM
cwpeden And don't use head gaskets. I used them for th... Aug 16 2016, 12:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 10:23 AM |
