| CG-914 |
Feb 7 2013, 12:23 AM
Member ![]() ![]() Group: Members Posts: 327 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
I know that oil pumps are the bases for discussion, but:
I do have a type for and a type 1 pump, But I like the Idea of having a type 4 pump, that lines up and is made out of aluminum, like this one. http://www.cbperformance.com/ProductDetail...roductCode=1829 It has the same expansion rates like the block. Has anyone used it? What is the QUALITY? (IMG:style_emoticons/default/wacko.gif) |
| Keith914 |
Aug 15 2016, 06:26 PM
Member ![]() ![]() Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
Before purchasing a new steel cover plate, L will bolt on the lapped cover plate that was badly non flat and is now true flat. Any thoughts on how much torque given that it is aluminum?
CG-914 Oil Pump Feb 7 2013, 12:23 AM
Mark Henry I've used a CB pump before, quality and fit is... Feb 7 2013, 04:49 AM
Keith914
I've used a CB pump before, quality and fit i... Aug 14 2016, 04:27 PM
Mark Henry
Jupump bolts which I was able to tighten a littl... Aug 14 2016, 06:04 PM
Keith914
I've used a CB pump before, quality and fit i... Aug 14 2016, 05:07 PM
Keith914 Thanks Mark, great info. and explanation of the pu... Aug 14 2016, 08:00 PM
Mark Henry
I assume the parts stores know what "Threeb... Aug 15 2016, 07:53 AM
injunmort i use yamabond on the cases and hylamar on EVERYTH... Aug 14 2016, 08:26 PM
Keith914 Cover gasket also from cipl.com?
Thanks again, Kei... Aug 15 2016, 08:20 AM
396 I bought a high volume type 4 from Fat Performance... Aug 15 2016, 08:35 AM
Mark Henry
I bought a high volume type 4 from Fat Performanc... Aug 15 2016, 09:32 AM
Keith914 Just talked with CB Performance technical guy. Hav... Aug 15 2016, 09:52 AM
forrestkhaag Just back from a drive-by to Keith's place to ... Aug 15 2016, 05:55 PM
Keith914
Before purchasing a new steel cover plate, L will... Aug 16 2016, 06:45 PM
injunmort not to hi jack, mark henry, i know yamabond comes ... Aug 16 2016, 08:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th September 2026 - 01:48 PM |
