> Dropped a valve seat...what's the verdict?
billh1963
post Aug 15 2016, 04:29 PM
Car Hoarder!
Way back in August 2013 I went to start my 914 and heard a funky noise. I immediately shut it down. Using my limited mechanical knowledge (and a tremendous amount of luck) I postulated that I had dropped a valve seat.
Three years later I decide it's time to get this 914 back on the road. Pulled the heads and, sure enough, a dropped valve seat. Prior to the issue the car was running good...no smoking, seemingly good oil pressure, etc.
I'm hoping I can get by with just rebuilding the head (if possible). Anyone see anything that would cause me to deviate from this plan of action?
HAM Inc
post Aug 15 2016, 06:43 PM
The seat drop repair alone is not so bad, as far as consequences to the casting's integrity. But the crack out the exhaust port is a real killer for the T4. It can be repaired, (done it countless times over the past 20 years) but the casting will never be the same.
Time to stick a fork in that one.
BTW, those cracks were really common on smog heads. Is your head one of them? Just curious.
ConeDodger
post Aug 15 2016, 07:47 PM
Apex killer!
QUOTE(HAM Inc @ Aug 15 2016, 08:43 PM) *
Len is of course one of the few people you could trust with a repair of this sort. The problem is, it has become economically unfeasible to do this repair. The valve seats aren't a big deal as Len said. In fact they should be done on any rebuild of a Type IV head. Len puts the heads in an oven without valves in place and many of the seats fall out just due to the heat. The welding needed to repair the cracks, and if I can see three? There are at least a couple more is the killer. It becomes pretty quickly cheaper to just buy a set of the LE200 heads and cook yourself up a 2056 or 2270.
Sorry...
billh1963   Dropped a valve seat...what's the verdict?   Aug 15 2016, 04:29 PM
Mike D.   I did the same thing back in 2000. Had the head re...   Aug 15 2016, 04:36 PM
ConeDodger   I see at least two and maybe three cracks in that ...   Aug 15 2016, 04:46 PM
billh1963   I see at least two and maybe three cracks in that...   Aug 15 2016, 04:54 PM
porschetub   I see at least two and maybe three cracks in that...   Aug 15 2016, 05:05 PM
porschetub   Oh dear the head is scrap ,not worth the repair co...   Aug 15 2016, 05:01 PM
billh1963   Oh dear the head is scrap ,not worth the repair c...   Aug 15 2016, 05:08 PM
r_towle   Depending upon your finances I would suggest you b...   Aug 15 2016, 06:04 PM
76-914   Is that piston cracked above the indentation?   Aug 15 2016, 06:13 PM
billh1963   Is that piston cracked above the indentation? I...   Aug 15 2016, 06:27 PM
HAM Inc   The seat drop repair alone is not so bad, as far a...   Aug 15 2016, 06:43 PM
billh1963   The seat drop repair alone is not so bad, as far ...   Aug 15 2016, 06:45 PM
ConeDodger   The seat drop repair alone is not so bad, as far ...   Aug 15 2016, 07:47 PM
HAM Inc   The seat drop repair alone is not so bad, as far...   Aug 16 2016, 09:29 AM
Philip W.   Looks like you will be building that 2056 --- you ...   Aug 15 2016, 08:08 PM
Toast   I've had a valve seat embedded in a head befor...   Aug 15 2016, 11:40 PM
cwpeden   And don't use head gaskets. I used them for th...   Aug 16 2016, 12:40 AM
- Lo-Fi Version Time is now: 4th March 2026 - 11:57 AM
