| billh1963 |
Aug 15 2016, 04:29 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,427 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Way back in August 2013 I went to start my 914 and heard a funky noise. I immediately shut it down. Using my limited mechanical knowledge (and a tremendous amount of luck) I postulated that I had dropped a valve seat.
Three years later I decide it's time to get this 914 back on the road. Pulled the heads and, sure enough, a dropped valve seat. Prior to the issue the car was running good...no smoking, seemingly good oil pressure, etc. I'm hoping I can get by with just rebuilding the head (if possible). Anyone see anything that would cause me to deviate from this plan of action? |
| DRPHIL914 |
Aug 15 2016, 08:08 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,889 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
Looks like you will be building that 2056 --- you had one before so you know how they compare to a stock 2.0
I'd say get the new heads- match them up with some nice new p&c's and back on the road in no time! |
billh1963 Dropped a valve seat...what's the verdict? Aug 15 2016, 04:29 PM
Mike D. I did the same thing back in 2000. Had the head re... Aug 15 2016, 04:36 PM
ConeDodger I see at least two and maybe three cracks in that ... Aug 15 2016, 04:46 PM
billh1963
I see at least two and maybe three cracks in that... Aug 15 2016, 04:54 PM
porschetub
I see at least two and maybe three cracks in that... Aug 15 2016, 05:05 PM
porschetub Oh dear the head is scrap ,not worth the repair co... Aug 15 2016, 05:01 PM
billh1963
Oh dear the head is scrap ,not worth the repair c... Aug 15 2016, 05:08 PM
r_towle Depending upon your finances I would suggest you b... Aug 15 2016, 06:04 PM
76-914 Is that piston cracked above the indentation? Aug 15 2016, 06:13 PM
billh1963
I... Aug 15 2016, 06:27 PM
HAM Inc The seat drop repair alone is not so bad, as far a... Aug 15 2016, 06:43 PM
billh1963
The seat drop repair alone is not so bad, as far ... Aug 15 2016, 06:45 PM
ConeDodger
The seat drop repair alone is not so bad, as far ... Aug 15 2016, 07:47 PM
HAM Inc
The seat drop repair alone is not so bad, as far... Aug 16 2016, 09:29 AM
Toast I've had a valve seat embedded in a head befor... Aug 15 2016, 11:40 PM
cwpeden And don't use head gaskets. I used them for th... Aug 16 2016, 12:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 10:23 AM |
