| 7TPorsh |
Aug 21 2016, 06:56 PM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
The other morning my car wouldn't crank; lights on dash but no juice. So I charge the battery up and start the car....drive around for a bit. Stop and start after half hour. OK
rive some more and get home...turn the car off and same thing; no juice. I take the battery to FLAPS who analyzes it and says it's bad....even though my meter says 12.5 volts. I get a new battery and installl. Car starts and runs and I drive back to FLAPS to test system in the car. Master guru technician says machine says I need a new voltage regulator. Of course they don't car it so I drive back home. i get in the DD and hunt down a new voltage regulator and put it in. Car start and drives...so i drive back to FLAPS. On the short drive there the car is running "on and off". i make it there. the 2nd master guru technician hooks up the meter and I manage to barely get the car started and running but it shuts off. He tells me the same thing again, the voltage regulator is bad. I say i changed the voltage regulator and he says no its the one in the alternator. (IMG:style_emoticons/default/blink.gif) So I coast the car back towards home but couldn;t get it started...going to try again later. \ So does this sound like a bad alternator? Car cranks but wont fire. Always thought it would run off the battery if alt is bad. Please help. |
| Toast |
Aug 22 2016, 11:17 AM
Not bad for carrying sway bars. ![]() ![]() ![]() ![]() Group: Members Posts: 3,380 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
The symptom is the generator light comes on. ;-)
You can get things like dim lights or slower starting. But usually it just goes out. I was able to drive all the way from Riverside to Jean Nevada on just the battery only before I finally didn't want to chance it the rest of the way. That's about a three and a half hour drive with headlights on. Could possibly be the starter. If the alternator is getting weak your voltage will be lower. Its easier to test the alternator and the battery. I can get a voltage regulator fairly cheap here in Vegas. Let me know if you need me to locate you one. |
7TPorsh What Are the Symptoms of a Bad Alternator Aug 21 2016, 06:56 PM
dangrouche here is the comprehensive thread involving the alt... Aug 21 2016, 08:24 PM
porschetub
here is the comprehensive thread involving the al... Aug 21 2016, 11:21 PM
injunmort car will start with 11 or so volts, will run down ... Aug 21 2016, 08:30 PM
7TPorsh Car cranks but does not start now. Aug 21 2016, 08:43 PM
colingreene Fuel air and spark, its one of those things. Aug 21 2016, 11:19 PM
McMark
Master guru technician says....
2nd master guru t... Aug 22 2016, 05:52 AM
The Cabinetmaker Master guru tech at flaps. :rotfl: :rotfl: :jer... Aug 22 2016, 07:20 AM
7TPorsh Yes, guys, master guru is sarcastic term. ....I d... Aug 22 2016, 08:57 AM
The Cabinetmaker Yes. You can remove the alternator and still run t... Aug 22 2016, 09:12 AM
McMark Yup. Curt is right. The alternator's only pu... Aug 22 2016, 09:59 AM
7TPorsh I can't rely on the dash lights; not sure it... Aug 23 2016, 11:28 AM
The Cabinetmaker Have you checked belt tension? Aug 23 2016, 02:11 PM
7TPorsh
Thanks Curt, ya ... Aug 23 2016, 03:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:37 AM |
