WTB stock heads/Head work question, Questions on heads. |
Localboy808 |
Aug 28 2016, 01:57 PM
Member Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None |
So. Did a compression check on my new 914. 90/90/85/90. Adjusted the valves. No change. Added some oil to one cylinder. No change. I'm guessing valves. When I got this car it had a bad exhaust leak. Come to find it was missing all the copper gaskets at the head and both collector gaskets. I'm not the expert when it comes to heads. But I'm guessing the missing gaskets could have caused some damage at the valves? Especially if it was driven a lot like that? So my question is. Any recommendations for someone on a budget? They are four bolt intakes so 1.7 or 1.8 heads. Not sure really. Anyone have a used decent set for sale? Any advice as far as getting them rebuilt? I'm in So Cal.
Thanks! Scott |
jim_hoyland |
Aug 28 2016, 02:39 PM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Based on your VIN; your car is a '72 ?
IIRC, that is a 1.7 motor |
Localboy808 |
Aug 28 2016, 02:48 PM
Based on your VIN; your car is a '72 ? IIRC, that is a 1.7 motor Yes. And the engine block is an EA motor. So appears to be a 1.7. But it looks like some work was done to it in the past. I see red rtv sealant on a couple of the case bolts. And the heads and cylinders might look a bit fresher. I could be wrong. It's a confusing story with this car. But someone posted the VIN for this car a couple of years ago from a craigslist ad. And the ad back then said it had a 1.8. So I'm not really sure. |
Lo-Fi Version | Time is now: 7th June 2024 - 07:43 PM |
