Oil: Cooling, flow rate and whats best? No answer; just thoughts. |
Cracker |
Aug 29 2016, 04:44 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
I've been thinking of this lately...
So when selecting an oil filter, there are variables such as flow rate, surface area of the filter itself and line size restrictions. So when using an external oil cooler, which in theory, would work most efficiently "holding" the oil for longer, extracting more energy in its exchange - does it make sense to use the "lowest" flow rated filter that conversely meets the maximum demand of the engine? This is relative with any engine that uses oil; and that oil gets hot - not an oil cooled/water cooled issue - neither are immune and both could benefit from the most efficient set up. Many "oil filters" claim hi-volume flow rate (28 gallons per minute!) - whats that good for if my max engine oil flow rate at WOT/Max temp is 6 GPM? The obvious opposing theory is that the longer oil is contained in an engine - the hotter it gets. So what would be the perfect formula for engine temp and oil quench? What say you? Tony |
Cracker |
Aug 30 2016, 06:03 AM
Chris - My specific situation has proven to be difficult - a tough nut to crack. Thus the reason I've been thinking allot of the subject over the last six-mounts. Mid-engine cars that don't have crazy scoops and such are at a disadvantage when it comes to controlling all things heat. Mine is no exception. Maybe I'll do something "crazy" and my oil temp issue will be bye, bye. Thanks.
BTW: I'm currently running a combined 76 rows of oil cooler on a 11" core - that's a ton of cooler for any car. In my case, I don't have adequate air-flow, with the coolers mounted in the rear of the car. Tony |
ChrisFoley |
Aug 30 2016, 06:28 AM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I don't have adequate air-flow, with the coolers mounted in the rear of the car. Moving to a front mounted cooler with exposed hard lines (recessed in the 2 channels below the tunnel) will make a dramatic difference in cooling results. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 08:51 AM |
