Idle Speed Issue - 1975 1.8L |
telank |
Aug 29 2016, 10:00 AM
Newbie Group: Members Posts: 8 Joined: 23-August 15 From: Indiana Member No.: 19,091 Region Association: Upper MidWest |
I'm in need of ideas to resolve an idle speed dilemma. My 914 is a 1975 1.8L which I bought about a year ago. It seems to be very stock and still has the L Jetronic FI system in place. Here is the challenge.... I have been using the process in the Haynes manual for setting idle speed. If I set the speed when the car is warm, the next time t is started cold it is difficult to start and will idle so slow it barely stays running. Once warmed up all is good. If I set the idle speed right after starting before it is up to temperature - after it does warm up - it will be idling at over 2,000 RPM. Outside of this issue the car runs good and strong. The plugs are perfect color - so no indication of too lean or rich mixture. Thanks for your thoughts or ideas!
telank |
Aug 30 2016, 03:10 PM
Last evening I removed the AAR to investigate the problem further. When I went to disconnect the wiring harness the heater element pulled right out of the housing of the AAR! A pic is attached. I applied 12v to the heater connector pins and the heating element started to warm. I didn't have time to watch long enough to ensure the bimetallic strip moved, but warmth seemed like a good start! I also was able to loosen up the internals using WD40. The internal "valve" mechanism appears to be spring loaded. So I assume when I put this back together I need to position the bimetallic strip so that it pushes against the spring loading and the valve is open when cold and as it heats and moves the spring pressure will close off the air passageway? Am I thinking correctly? Also, is there any reason why epoxy would not be a good choice to glue the heating element assembly back into the housing?
Lo-Fi Version | Time is now: 10th June 2024 - 10:59 AM |
