Idle Speed Issue - 1975 1.8L |
telank |
Aug 29 2016, 10:00 AM
Newbie Group: Members Posts: 8 Joined: 23-August 15 From: Indiana Member No.: 19,091 Region Association: Upper MidWest |
I'm in need of ideas to resolve an idle speed dilemma. My 914 is a 1975 1.8L which I bought about a year ago. It seems to be very stock and still has the L Jetronic FI system in place. Here is the challenge.... I have been using the process in the Haynes manual for setting idle speed. If I set the speed when the car is warm, the next time t is started cold it is difficult to start and will idle so slow it barely stays running. Once warmed up all is good. If I set the idle speed right after starting before it is up to temperature - after it does warm up - it will be idling at over 2,000 RPM. Outside of this issue the car runs good and strong. The plugs are perfect color - so no indication of too lean or rich mixture. Thanks for your thoughts or ideas!
Dave_Darling |
Aug 31 2016, 01:00 PM
One thing that can be done to estimate the amount of flow through the two valves would be to measure the opening of the valve when it is all the way open. If you have the disc-style one apart, you can just measure the opening in the disc or trace it on paper or some such. Measuring the rotary one would be a bit more difficult, but if someone has it completely apart they should be able to measure the hole.
I don't know how the openings in the valves compare. My guess is they are at least somewhat similar, because some early 74 1.8s used the rotary valve style AAR, like the D-jet cars did. But that is just a guess. --DD |
Lo-Fi Version | Time is now: 10th June 2024 - 07:11 AM |
