Oil: Cooling, flow rate and whats best? No answer; just thoughts. |
Cracker |
Aug 29 2016, 04:44 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
I've been thinking of this lately...
So when selecting an oil filter, there are variables such as flow rate, surface area of the filter itself and line size restrictions. So when using an external oil cooler, which in theory, would work most efficiently "holding" the oil for longer, extracting more energy in its exchange - does it make sense to use the "lowest" flow rated filter that conversely meets the maximum demand of the engine? This is relative with any engine that uses oil; and that oil gets hot - not an oil cooled/water cooled issue - neither are immune and both could benefit from the most efficient set up. Many "oil filters" claim hi-volume flow rate (28 gallons per minute!) - whats that good for if my max engine oil flow rate at WOT/Max temp is 6 GPM? The obvious opposing theory is that the longer oil is contained in an engine - the hotter it gets. So what would be the perfect formula for engine temp and oil quench? What say you? Tony |
Dave_Darling |
Aug 31 2016, 01:07 PM
I'm talking water-to-oil heat exchanger. It shouldn't have to be huge, and since you can plumb oil and coolant lines around the car wherever you like, you should have a good amount of flexibility in where to put it.
Like I said, some Hondas had an exchanger that went in between the block and the oil filter. Spaced the filter out a couple of inches, maybe, and helped with oil temps. --DD |
Lo-Fi Version | Time is now: 10th June 2024 - 11:47 PM |
