parts needed for tail to side shift conversion, want a list of EVERYTHING needed |
914 RZ-1 |
Aug 26 2016, 06:03 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I've read a few of the posts about converting a tail shift to a side shift. What I was not able to find is a detailed list of what parts I need.
I did look at the PET and made a list of the hardware (bolts and nuts) that I can get at a local place (not a home improvement store) that has the Grade 8 hardware needed for this application. It looks like I also need (numbers are same as on PET illustration 119-00): 1. L & R supporting plate 2. engine mounting (rubber bushing) 9. engine carrier (bar) 11. base Anything else? What else do I need for the inside of the trans? Looks like I need 3 shifter forks and part numbers 13-28 on the PET (illustration 304-05). Anything else? Tell me item numbers in the PET so I can see what they look like. I'd like to do a search in the FS section and see if anyone has the various pieces. Thanks! |
rhodyguy |
Sep 1 2016, 08:35 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
L&R brackets and bolts for the inboard engine mounts. With the stock shifter, new bushings that cradle the lever pivot ball. The 1&R detent plate should be nice and straight, almost a sharp edge, and no grove cut into shift lever at the contact point.
Lo-Fi Version | Time is now: 28th May 2024 - 04:46 PM |
