| GregAmy |
Aug 7 2016, 09:43 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,700 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Nice beautiful New England Day, heading off to the Manchester CT car show and...car won't start. Cranks, a few cylinders fire, then it dies. I cycle the key and hear the pump running and then stop (as before) and same thing: spits then dies.
I tried cycling the key a few times, with the mindset of building more pressure, and it spits a few more cylinders then dies. Even got it to rev a little bit with a half-dozen key cycles, but always dies. Only other symptoms is that I noticed the last time I drove it earlier in the week it was dying when I put in the clutch. Was not consistent, only did ti a few times, but that was unusual behavior. Stock 2L fuel injection, but with cold start and idle air bypass systems disabled; been running fine like this for the several years I've had it. Checked all the relays, each works with the heater blower. Swapping them makes no difference (which I expected, given the pump cycles with the key). My guess is that however the pump is supposed to continue to run after releasing the key, it's not getting the power it needs (just a guess, I've not gotten under there with a voltmeter to verify). The wiring diagrams are not clear (to me) how that power is applied to the fuel pump relay. Any way to quickly salvage my afternoon trip to the car show, or am I using my beautiful afternoon to swap the street car onto the lift for extended diagnosis? 40-yr-old electrics, gotta love 'em. - GA |
| GregAmy |
Sep 4 2016, 07:53 AM
Another data point.
I was considering hitting the Lime Rock Historics car show today, figured I'd let the 914 decide if we were going. The 914 decided we're not going, it would not start. Fuel pump cycles with the key, car cranks fine. After a couple revolutions it briefly fires, then dies. I can continue that for a seemingly infinite number of key cycles: key on, pump on, crank, briefly ignition for a few cylinders, dies. It's not the fuel pump circuit. I jumped between 30 and 87 on the relay plate and the fuel pump is audibly running, car does the same thing: briefly fires then dies. I can also smell fuel so I'm confident I have fuel flow/pressure. I'm thinking either ignition or something in the engine management. No motivation to deal with this until October. I momentarily considered driving the licensed rollcaged 914 2L race car to this event, but an hour-and-a-half on a race suspension and 13-yr-old Hoosiers just didn't appeal to me. I'll play with the race car next weekend at Palmer (it's getting replacement tires before then). -GA Edit: I have neither a spare MPS nor spare CHT sensor to check, so this will need to wait until another day. |
GregAmy '74 2L Starts Then Dies Aug 7 2016, 09:43 AM
GregAmy So I removed the relay panel harness connector, th... Aug 7 2016, 10:01 AM
The Cabinetmaker Its all in the Brad Anders website. Brads 914 2.0L... Aug 7 2016, 12:17 PM
GregAmy Made it to the show and back, but it was cutting o... Aug 7 2016, 12:54 PM
The Cabinetmaker Go here
http://members.rennlist.com/pbanders/DJe... Aug 7 2016, 12:58 PM
boxsterfan Stock pump in stock location on stock wiring?
If ... Aug 7 2016, 01:18 PM
GregAmy Thanks. Do you know if "19 and relay plate te... Aug 7 2016, 01:36 PM
GregAmy Ok, so maybe this thing isn't worked out yet..... Aug 29 2016, 10:16 AM
BeatNavy
I've checked the head temp sensor and it... Aug 29 2016, 10:33 AM
Sleepin Fuel pump? Sometimes when fuel pumps start to fail... Aug 29 2016, 10:24 AM
76-914 I'm going to suggest that you install a FP pre... Aug 29 2016, 03:48 PM
GregAmy Thanks for the tips.
I don't think it's t... Aug 30 2016, 05:56 AM
Philip W.
I don't think it's ... Aug 30 2016, 06:41 AM
BeatNavy
As for the head temp sensor...man, trying to trou... Aug 30 2016, 06:49 AM
Shadowfax What type of plugs are you using and what is their... Aug 30 2016, 06:49 AM
injunmort fuel sock and fuel filter, first. Aug 30 2016, 05:13 PM
GregAmy OK, I lied, couldn't stay away from it. Since ... Sep 4 2016, 02:54 PM
GregAmy And more randomly-chucking darts toward a blank wa... Sep 4 2016, 03:24 PM
injunmort i am starting to suspect a duff coil and just for ... Sep 4 2016, 04:19 PM
76-914 Fuel pressure. Well I'll be. As far as the int... Sep 4 2016, 09:04 PM
GregAmy I don't believe it's an ignition problem. ... Sep 4 2016, 09:17 PM
GregAmy Aaaaand it's back. After starting and running ... Mar 9 2017, 03:34 PM
GregAmy Ok, yeah, this thing is really pissing me off now.... Mar 9 2017, 04:29 PM
Porschef Sure seems like fuel. Sounds like your pump is ru... Mar 9 2017, 04:52 PM
GregAmy And OF COURSE it starts fine yesterday and today. ... Mar 11 2017, 10:18 AM
GregAmy I'm not convinced it's fuel pump or pressu... Mar 9 2017, 05:14 PM
ThePaintedMan I had a similar problem, but in a more modern car.... Mar 9 2017, 05:26 PM
76-914 Greg, just for "shits n grins" check you... Mar 9 2017, 06:15 PM
GregAmy Thanks for the tips; keep 'em comin'!
... Mar 9 2017, 06:22 PM
Dave_Darling How's the fuel pressure? You've been kick... Mar 9 2017, 06:57 PM
GregAmy OK, here's some more data.
I was playing arou... Mar 11 2017, 11:41 AM
Dave_Darling The CSV is powered by the yellow starter wire. It... Mar 11 2017, 07:19 PM
McLovin Aren't the injectors electrical? Maybe you... Mar 12 2017, 12:17 AM
Dave_Darling The only injectors I know of that are not electric... Mar 12 2017, 11:10 AM
McLovin
The only injectors I know of that are not electri... Mar 12 2017, 11:36 AM
GregAmy 30 psi.
See post #32, specifically paragraph 2. Mar 12 2017, 11:24 AM
Dave_Darling
30 psi.
... Mar 13 2017, 03:36 PM
The Cabinetmaker Sounds like Mctrolling to me. Mar 12 2017, 12:14 PM
Jeff Bowlsby There is always Chris Foley around the corner from... Mar 13 2017, 03:45 PM
Mike D. Fuel injector Trigger points in the distributor...... Mar 13 2017, 04:02 PM
GregAmy
There is always Chris Foley around the corner fro... Mar 13 2017, 04:25 PM
Mike D.
There is always Chris Foley around the corner fr... Mar 13 2017, 08:01 PM
GregAmy And the answer is...(or seems to be...)
Wait for... Apr 6 2017, 09:10 AM
Philip W.
Wait fo... Apr 6 2017, 10:13 AM
GregAmy I did!!!! Post #13 on first page... Apr 28 2017, 06:54 AM![]() ![]() |
Lo-Fi Version | Time is now: 20th September 2026 - 12:08 AM |
