> Stumped, Low Compression
AKJammer
post Sep 7 2016, 09:04 PM
Engine: 1.8 1974.
I tore down the engine to replace Dead gaskets and seals.
Purchased new jugs and pistons reassembled the engine. Fired it up and have 90 lbs of compression on 3-4 125 on 1-2.
Completed a leak down test and all is good as it is holding what compression there is...
Tore the engine down again and measured the cc of the heads and they are all the same. Part number 021.101.371S on both heads.
Measured the deck height of the pistons at TDC and they are all the same....
Head gasket shims are all the same.
What am I missing???
Thanks Jammer!
old dog
post Sep 9 2016, 08:54 PM
Just a thought.... Is the cam timing correct ? Good leakdown, different compression side to side.... Cams not timed properly
Again, just a thought.
rgalla9146
post Sep 10 2016, 04:03 AM
QUOTE(old dog @ Sep 9 2016, 10:54 PM) *
......that would require a Very special cam
AKJammer   Stumped   Sep 7 2016, 09:04 PM
rgalla9146   Fuel injection or carbs ? If carbs, were the ca...   Sep 7 2016, 09:14 PM
AKJammer   Fuel injection or carbs ? If carbs, were the c...   Sep 7 2016, 09:19 PM
rgalla9146   Fuel injection or carbs ? If carbs, were the ...   Sep 8 2016, 05:42 AM
Root_Werks   [quote name='AKJammer' post='2395384' date='Sep 7...   Sep 8 2016, 12:15 PM
AKJammer   [quote name='AKJammer' post='2395384' date='Sep ...   Sep 8 2016, 01:07 PM
injunmort   ring gap, ring stagger, valve seats, valve clearan...   Sep 7 2016, 10:29 PM
AKJammer   ring gap, ring stagger, valve seats, valve cleara...   Sep 7 2016, 10:46 PM
wndsrfr   ring gap, ring stagger, valve seats, valve clear...   Sep 8 2016, 05:27 AM
stugray   Rings haven't seated.....drive it like you st...   Sep 8 2016, 05:49 AM
The Cabinetmaker   Sounds like an aka problem   Sep 8 2016, 06:00 AM
Vacca Rabite   Compression on a fresh top end-er builds as the ri...   Sep 8 2016, 07:57 AM
injunmort   if it were mine and it is out and apart. i would d...   Sep 8 2016, 07:58 AM
AKJammer   Thanks All! I have some Ideas of what to do n...   Sep 8 2016, 12:10 PM
r_towle   You may want to check to make sure the case is fla...   Sep 8 2016, 07:05 PM
Root_Werks   Also noting you stated 3-4 "side" doesn...   Sep 9 2016, 10:18 AM
old dog   Just a thought.... Is the cam timing correct ? Goo...   Sep 9 2016, 08:54 PM
rgalla9146   Just a thought.... Is the cam timing correct ? Go...   Sep 10 2016, 04:03 AM
- Lo-Fi Version Time is now: 16th March 2026 - 01:15 AM
