| Spoke |
Sep 12 2016, 11:01 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,349 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I bought this allegedly running-when-it-was-pulled 2L engine last year to upgrade to 2.056L just to find out it already had 96mm P&C.
Internals turns smoothly so I thought I'd do the flame test and clean the engine and put it back together. The engine runs strong and smooth. As I started driving it harder I noticed on fast deceleration the oil light would come on. If I let the engine speed come down naturally from about 2k, the oil light doesn't come on. Last night coming off the highway running about 3.2k, I immediately shifted into neutral to let the engine slow on its own, the oil light came on for a few seconds as the engine was now idling. I don't have an oil pressure gauge on it to see where the oil pressure is during operation. Any ideas of what to look at? Attached thumbnail(s) |
| VaccaRabite |
Sep 13 2016, 07:39 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,840 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Internal clearances may be too high.
But I would check all the other stuff first, and get a pressure gauge on there asap. Until you know what your pressure is dropping to, all we are doing is spit balling. I don't like the dual pole senders, BTW. They have the idiot light set at about 9 PSI, much higher then the stock sender. I have a single pole pressure sender, and a stock idiot light sender on a Y block. |
Spoke Low Oil Pressure on Hard Deceleration Sep 12 2016, 11:01 AM
Tom_T Spoke,
Both my `73 914-2.0 & our `88 ... Sep 12 2016, 11:21 AM
Vacca Rabite Chris Foley was selling a pressure booster that re... Sep 12 2016, 12:54 PM
boxsterfan
Chris Foley was selling a pressure booster that r... Sep 12 2016, 01:00 PM
brant I'd replace the sending unit too.
put on a dua... Sep 12 2016, 01:10 PM
The Cabinetmaker I don't think Chris' valve was intended to... Sep 12 2016, 01:41 PM
'73-914kid I would recommend installing a tuna can on the sum... Sep 12 2016, 03:00 PM
'73-914kid Also, what oil and weight? Sep 12 2016, 03:01 PM
Spoke
Valvoline VR1 20W-50... Sep 12 2016, 08:32 PM
914Bryan I agree with what Ethan said about overfilling the... Sep 12 2016, 03:14 PM
Dave_Darling Every time I have had the oil light come on under ... Sep 12 2016, 08:04 PM
Spoke
I have a single pole pressure sender, and a stock... Sep 13 2016, 08:26 AM
Dave_Darling
Also, where to buy an oil pressure gauge and send... Sep 13 2016, 09:33 AM
colingreene Do you know for sure that the windage tray is in i... Sep 13 2016, 11:46 PM
Spoke
Do you know for sure that the windage tray is in ... Sep 14 2016, 01:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 5th March 2026 - 10:33 AM |
