> Survey: Just how "ineffective" is standard for heat blower?, Max Defrost = no front blower on = no air coming out of vents
MikeInMunich
post Sep 18 2016, 10:25 AM
Happy First Sunday of the Oktberfest Gentlemen! PROST, from Munich! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/smilie_flagge6.gif)
Curious about this almost comical "instruction on our ventilation controls..."MAX DEFROST, upper levels left, lower lever right"...I was thinking, how is this correct, when the upper lever left turns the blower onto the windshield OFF?!
So I found this thread...
http://www.914world.com/bbs2/lofiversion/i...php?t75480.html
and then I went out and tested to see how much warm air from the back is actually blowing out of the vents at the windshield. Virtually NONE was coming out at all.
So...before I go seeking the possible reason, I'm curious about others' results for this same test. What is the best / normal (stock) result here? The hoses in the compartment were OK. I haven't checked those under the car or the dash yet.
How much more effective would a stronger blower be? Power / spec suggestions?
Thanks guys, and have a great Sunday!
Mike in Munich
BeatNavy
post Sep 18 2016, 02:55 PM
In my experience you should be able to noticeably feel air coming out. That's about it. At its best it's not going to blow you away like the max fan setting on a modern car. I actually took my blower out after futzing with it and trying to optimize the volume of air it would put out. It clutters the engine bay and I get enough heat/defrost from the engine fan.
Having said THAT...the teener has been relegated to outside the garage to make room for my wife's car. I drove all winter last year, but it's going to be a different story with the car starting outside and exposed to the elements in the winter mornings... (IMG:style_emoticons/default/dry.gif)
MikeInMunich
post Sep 18 2016, 11:17 PM
QUOTE(BeatNavy @ Sep 18 2016, 12:55 PM) *
Sounds like I need to check the tubes. The air isn't getting into the cabin the way it should. So, my HEAT should be really BLOWING onto my feet, instead of "drifting" (light blowing) into the cabin?
MikeInMunich   Survey: Just how "ineffective" is standard for heat blower?   Sep 18 2016, 10:25 AM
GeorgeRud   The black levers control fresh air, the red levers...   Sep 18 2016, 10:53 AM
The Cabinetmaker   I have found the best defrost comes from all three...   Sep 18 2016, 10:58 AM
MikeInMunich   This only seems logical, which makes me wonder abo...   Sep 18 2016, 02:34 PM
BeatNavy   In my experience you should be able to noticeably ...   Sep 18 2016, 02:55 PM
MikeInMunich   In my experience you should be able to noticeably...   Sep 18 2016, 11:17 PM
Garold Shaffer   In my experience you should be able to noticeably...   Sep 19 2016, 06:18 AM
Mark Henry   In my experience you should be able to noticeabl...   Sep 19 2016, 07:16 AM
scott_in_nh   :agree: When I had my 2.0 SSI's, late oct...   Sep 19 2016, 03:07 PM
BeatNavy   Yes, check for blockages and make sure all the tub...   Sep 19 2016, 03:52 AM
saigon71   Yeah, check your hoses. I've got a completely...   Sep 19 2016, 06:11 AM
malcolm2   http://www.volksbolts.com/faq/cooling.htm Maybe ...   Sep 19 2016, 07:32 AM
Brian Mifsud   I've always kept my blower/heat exchanger syst...   Sep 19 2016, 10:53 AM
MikeInMunich   Thanks for the info! So how does one access ...   Sep 20 2016, 01:19 PM
malcolm2   Thanks for the info! So how does one access...   Sep 21 2016, 11:05 AM
BeatNavy   That is how I did it. Behind the speaker pod is ...   Sep 21 2016, 11:19 AM
MikeInMunich   quote] Look at your plumbing on this though, inclu...   Sep 21 2016, 02:03 PM
MikeInMunich   Thanks! :beer2:   Sep 21 2016, 01:59 PM
mepstein   Thanks for the info! So how does one access...   Sep 21 2016, 08:59 PM
rhodyguy   A functioning heating system should be able to war...   Sep 21 2016, 10:05 AM
JRust   At Red rocks we were having a discussion about hea...   Sep 21 2016, 04:37 PM
smj   ... came over & said my buddy went & boug...   Sep 21 2016, 08:14 PM
Garland   I have both exchangers hooked up, and the splitter...   Sep 21 2016, 08:36 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:00 PM
