| CG-914 |
Sep 21 2016, 11:56 AM
Member ![]() ![]() Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
Yes I did a search (IMG:style_emoticons/default/biggrin.gif)
First: 2.0 Type 4 engine... With a Mallory Distributor. I've done some research for the sending Unit for my VDO Oil Pressure Gauge 0-5 bar. The threat in the engine case is M10x1 Tapered. VDO offers a 0-5 bar Sending Unit with the right threat (even tapered) and two connecters: one gauge and one idiot light. VDO Part# 252.21.67 My question now is, does anybody have experiance of mounting it directly on the case? Especially in the car with the sheet meatall installed? Als does that work with the clearance to the Mallory Distributor? Thanks C |
BeatNavy
My [b]question now is, does anybody have experian... Sep 21 2016, 12:08 PM
Vacca Rabite Gotta use a hose.
Grease gun hose works, as does p... Sep 21 2016, 01:57 PM
N_Jay Make sure the hose end is metric threaded. The th... Sep 21 2016, 02:00 PM
Mark Henry
Make sure the hose end is metric threaded. The t... Sep 21 2016, 03:08 PM
N_Jay
Make sure the hose end is metric threaded. The ... Sep 21 2016, 03:33 PM
Racer Chris 27 TPI vs 25.4 TPI.
You'll never get 8 turns w... Sep 21 2016, 03:46 PM
N_Jay http://www.pacificcustoms.com/cnc896.html
https:/... Sep 21 2016, 03:47 PM
CG-914 Thanks guys. I was really hoping not to need a hos... Sep 22 2016, 05:13 AM
Mark Henry Don't forget the sender must be grounded to wo... Sep 22 2016, 07:18 AM
Vacca Rabite I also had to use teflon plumbers tape on the thre... Sep 22 2016, 07:30 AM
N_Jay
I also had to use teflon plumbers tape on the thr... Sep 22 2016, 08:10 AM
era vulgaris Do not use a grease gun hose or a paintball gun ho... Sep 22 2016, 07:58 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:30 PM |
