> Oil pressure relief valve.
Keith914
post Sep 23 2016, 10:21 AM
To the "brain trust". Two experienced engineer/mechanics have described the following:
When our Type IV engines are at operating temperature and rpm's exceed about 3,000 the pressure relief valve (ball bearing valve seen in the oil filter bracket) opens up and prevents or reduces oil flow through the filter. Thus, this reduces oil flow through external oil coolers attached via a "pancake" to the engine, greatly reducing there cooling effect when needed most, e.g. at the track. They have altered this valve so that it cannot open, and advised to keep rpm's low until the engine is warmed up -- particularly in cold climates. there are various ways to "plug" this valve, easy when removed from the engine, -- drill and thread a bolt with lock nut to hold the ball bearing closed, press in an aluminum plug, etc.
Two questions: 1) are there other (than too high an oil pressure with cold engine with higher rpm's) unintended consequences, and 2) can this valve be "plugged" and how, without removing the engine to get at it?
ChrisFoley
post Sep 23 2016, 02:53 PM
I am Tangerine Racing
a couple psi
Keith914   Oil pressure relief valve.   Sep 23 2016, 10:21 AM
Racer Chris   AFAIK, the only downside to disabling the bypass v...   Sep 23 2016, 10:48 AM
Elliot Cannon   Doesn't that valve open by oil pressure depres...   Sep 23 2016, 12:05 PM
Racer Chris   Doesn't that valve open by oil pressure depre...   Sep 23 2016, 01:19 PM
N_Jay   [quote name='Elliot Cannon' post='2402166' date='...   Sep 23 2016, 01:27 PM
N_Jay   Yes there are heavier springs. You can go up unti...   Sep 23 2016, 12:20 PM
Racer Chris   You can go up until you risk popping the oil fi...   Sep 23 2016, 01:23 PM
Racer Chris   Keith called it a relief valve, but he described t...   Sep 23 2016, 01:44 PM
The Cabinetmaker   Njay they are referring to the filter bypass ball ...   Sep 23 2016, 01:48 PM
N_Jay   Njay they are referring to the filter bypass ball...   Sep 23 2016, 02:00 PM
barefoot   Njay they are referring to the filter bypass ball...   Sep 24 2016, 04:56 AM
Racer Chris   a couple psi   Sep 23 2016, 02:53 PM
Keith914   I am referring to the valve that has a ball bearin...   Sep 23 2016, 04:53 PM
stugray   I ran my racecar for a whole season with a sandwic...   Sep 23 2016, 06:58 PM
stugray   This is the focus of the OP I believe: http://www...   Sep 24 2016, 06:59 AM
Keith914   Thanks for the input and flow diagrams. It is cle...   Sep 24 2016, 12:40 PM
jim_hoyland   Question: does the oil filter relief valve in effe...   Nov 3 2016, 02:20 PM
stugray   Question: does the oil filter relief valve in eff...   Nov 3 2016, 02:26 PM
jim_hoyland   Question: does the oil filter relief valve in ef...   Nov 3 2016, 04:18 PM
yeahmag   I've taken to pulling them out and TIGing in a...   Nov 3 2016, 05:01 PM
GregAmy   Just picked up on this topic (was away racing last...   Nov 4 2016, 08:52 AM
jim_hoyland   Does all the oil pass through the filter and then ...   Nov 4 2016, 04:31 PM
- Lo-Fi Version Time is now: 9th September 2026 - 01:41 AM
