Need help pronto...front trunk stuck closed. |
Cuda911 |
Sep 24 2016, 08:56 AM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Hey, so I' up here in Lake Arrowhead, and when I pull the handle for the front trunk cable it isn't releasing the latch. Any suggestions? Thanks in advance.
Cuda911 |
Sep 24 2016, 12:01 PM
Thank all. Anyone got a good write up on making an emergency release?
mepstein |
Sep 24 2016, 02:21 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Thank all. Anyone got a good write up on making an emergency release? You won't need one if you remove the cable from the housing and lube it with teflon or silicon based lube. Lube the pull under the dash. Lube the lock mechanism at the hood. Tighten the set screw properly. Then the release will work easily and properly every time. |
Lo-Fi Version | Time is now: 6th June 2024 - 10:38 PM |
