| malcolm2 |
Sep 26 2016, 10:09 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
Things to do before the 2017 Okteenerfest.
I want OEM seats, but the foam just ain't cuttin' it. 6 hours to and from Banner Elk was not comfortable at all. Even with a food break at 3 hours. IIRC the foam I currently have had 1985 stamped on it when I re-did the hardy board under the seat, so it is not original. But it is still old. Ideas? |
| malcolm2 |
Sep 27 2016, 07:52 AM
http://www.usafoam.com/seat&cushion/se...mp;cushion.html
These guys have some specs on foam.... LUX HQ sounds good to me.. Lux Foam - High Quality Firm foam for regular or heavy use. Lux Foam - HQ is a high quality foam suggested for seats, chairs, cushions, benches, and mattresses. Foam has a typical life of 16 years. (Lux-HQ foam is a 2.8 lb/ft3 density with a 50lb ILD) vs Lux Foam - Regular Firm foam for regular use. Lux Foam - R is suggested for seats, chairs, cushions, benches, and mattresses. Foam has a typical life of 7 years. (Lux-R foam is a 1.8 lb/ft3 density with a 50lb ILD) They have another similar to LUX that is call HD-36 with the only diff being it has 35LB ILD.... need to find out what ILD is. I am gonna assume I should just max out all the specs, years of life, density and ILD. Might be like sitting on a brick tho. I assume 2 seat btms would be 6" thick, maybe 24" x 60" for less than $70! |
| Frankvw |
Sep 27 2016, 09:28 AM
working on my first 914 ! ![]() ![]() ![]() Group: Members Posts: 653 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
They have another similar to LUX that is call HD-36 with the only diff being it has 35LB ILD.... need to find out what ILD is. I just checked online how to explain what ild is: (not my wisdom) What does the ILD rating of a memory foam mattress mean? ILD stands for Indentation Load Deflection. In simple terms it is a measurement of how hard or soft a foam is. In more accurate terms it's the number of pounds of pressure required to indent 4" of foam by 25% using a 50 square inch indentation. You may also see it referred to as the 25% ILD rating. For example, this means that a 15lb ILD rating would mean that the foam needed 15lbs of pressure to indent it by 25%, and a 25lb ILD rating would mean it needs 25lbs to indent by 25%, so basically this means that the higher the ILD, the firmer the foam. You can use the ILD rating together with the foam's density to gain a good idea of the overall make up and quality of the foam. It is worth noting that due to the batch production process of memory foam, the measured ILD and density ratings can change from batch to batch. It is not unusual for a foam that rates at 10lb ILD to vary between 8lb and 12lb. This can also vary depending on the temperature and environment the foam has been conditioned in prior to testing. |
malcolm2 Anyone have a good way to improve the comfort of the OEM seat? Sep 26 2016, 10:09 AM
mepstein I bought super dense foam on eBay. You can use an ... Sep 26 2016, 10:25 AM
malcolm2
I bought super dense foam on eBay. You can use an... Sep 26 2016, 10:43 AM
mgp4591
I bought super dense foam on eBay. You can use a... Sep 26 2016, 08:45 PM
914forme
Anyone ever try anything like wrestling mat shape... Dec 1 2018, 08:02 PM
Amphicar770 Search for "High Density Foam" Sep 26 2016, 10:56 AM
oakdalecurtis One modification I made to my drivers seat, since ... Sep 26 2016, 12:09 PM
Jamie I just took the original driver side seat to a loc... Sep 26 2016, 12:14 PM
Brian Mifsud This isn't my seat, but I bought an inflatable... Sep 26 2016, 12:22 PM
Mike Bellis Funny. My 914 is the only vehicle I own that can b... Sep 26 2016, 05:45 PM
horizontally-opposed Stock 914 seats are among the most comfortable roa... Sep 26 2016, 05:57 PM
Sedonut I've always loved the seats. Now and 40 years ... Sep 26 2016, 06:01 PM
malcolm2 I guess it is my ass and my tail bone. This is th... Sep 26 2016, 07:09 PM
My 914
I guess it is my ass and my tail bone. This is t... Sep 26 2016, 09:15 PM
I guess it is my ass and my tail bone. This is t... Sep 26 2016, 10:04 PM
JmuRiz
...Maybe it does have something to do with the fa... Sep 27 2016, 06:58 AM
db9146 Malcolm2, I agree with you. 5+ hours last year fr... Sep 26 2016, 07:27 PM
Jamie Have you investigated the optional seats at classi... Sep 26 2016, 08:17 PM
black73 914 Rubber has high density foam already cut to fi... Sep 27 2016, 04:34 AM
rmdinmd :agree: But I would still recommend not having ... Sep 27 2016, 05:25 AM
ClayPerrine I don't have a problem with 914 seats. They s... Sep 27 2016, 06:14 AM
Philip W. its a long drive in a 914 but my seats are very co... Sep 27 2016, 06:49 AM
malcolm2 OK, that is a measurement for sure. Shouldn't... Sep 27 2016, 09:36 AM
PanelBilly Your upholstery shop should know how to build a la... Sep 27 2016, 09:42 AM
malcolm2 Are the husks dried and cut into small pieces? I ... Sep 27 2016, 10:18 AM
Elliot Cannon I found the biggest problem for me was not having ... Sep 27 2016, 05:10 PM
bbrock :bump:
Bumping this thread to see if anyone has a... Dec 1 2018, 05:05 PM
bmtrnavsky How hard would it be to make the bolsters a little... Dec 4 2018, 04:52 PM
dr914@autoatlanta.com read the seat cushion, over the years the padding ... Dec 4 2018, 05:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:30 PM |
