| pbanders |
Sep 28 2016, 12:12 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 990 Joined: 11-June 03 From: Scottsdale, AZ Member No.: 805 Region Association: Southwest Region |
OK, I think I'm "finished" with my LED conversion on my car. I converted nearly every light in the car to LED's. Only lights I didn't convert were the fresh air fan indicator, and the non-illumination lights in the dash cluster. Headlights are WHDZ LED 7" from Amazon, all other bulbs from superbrightleds.com. Total cost including shipping and tax was $304. I originally tried H4 LED conversion bulbs but didn't like them, and went with the WHDZ lights instead, which meet my needs. I also converted my fog/driving lights to LED, the lights I bought were $14 a pair from Amazon, so including those brings me to $318.
My purpose was twofold: better lighting, and lower current draw. I hoped with the lower current draw that issues I've had with parasitic alternator drag pulling down the idle with the lights on would be improved. Both goals were definitely accomplished. With the stock incandescent lights, if you have the lights on and you're using the low beams, the current draw from all of the lights (marker lights, F/R parking lights, headlights, license plate lights, trunk light, instrument lights) is 19.5 A at 12.8 V. Replacing those lights with the LED's I described above results in a current draw of 5.0 A, a reduction of 14.5 A (~75% reduction). For the first time since I've owned this car, turning on the lights has no effect on the idle. You could probably do the same thing by changing the alternator to a 70 A or the 160 A conversion, but you wouldn't get the improvement in lighting and it would likely cost a lot more. I can even turn on the fresh air blower, heater, or windshield wipers with the lights on at idle - though I think if I turned them all on simultaneously that would be pushing my luck too far. The lighting is vastly improved. The marker and parking lights are far brighter, as is the reverse lighting (actually useful, now). I can see things in my trunk. My interior light actually lights my interior. My instrument markings are white now and not a dull yellow. I need to build a PWM dimmer for them that works off of the dimmer knob, as right now, they're "on" or "off" (kind of how LED's work with DC voltage). Headlights are vastly improved. They're so white that when I see cars with halogen lights they look like kerosene lanterns. I'm not a big fan of the WHDZ low beams (not as uniform a pattern as I'd like), but in combo with my fog/driving lights, they're awesome. The WHDZ high beams are excellent, great pattern and super throw. IMO, it's a good upgrade for our aging cars. Superbrightled's has a nice vehicle system that will tell you all the lights you need. You can find the WHDZ lights on Amazon easily if you search for "WHDZ", they're $64 ea. Or, you can go with the Truck-Lites (~$170 ea) or the GE Nighthawks (~$220). There are some other projector-style LED lights on Amazon if you want to go that way. Some pics below.... |
| N_Jay |
Sep 28 2016, 06:46 AM
Member ![]() ![]() Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
Any chance you can list the specific bulbs you use and sources?
Any lessons learned along that way, such as bulbs that seemed right but did not fit? |
| sfrenck |
Sep 28 2016, 06:49 AM
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region
Any chance you can list the specific bulbs you use and sources? Any lessons learned along that way, such as bulbs that seemed right but did not fit? (IMG:style_emoticons/default/agree.gif) I'm looking for the fog lights in particular |
| pbanders |
Sep 28 2016, 08:01 AM
Any chance you can list the specific bulbs you use and sources? Any lessons learned along that way, such as bulbs that seemed right but did not fit? (IMG:style_emoticons/default/agree.gif) I'm looking for the fog lights in particular For the majority of the lights, superbrightleds.com has a vehicle configurator, just enter your make/model/year and they tell you what you need. I don't have the front side marker lights, and I have Euro front buckets, so my configuration may be different than yours, here's what I bought from them:
The headlights are WHDZ 7" Round LED, with hi/lo beam and standard H4 plug (plugs right into your stock headlight harness socket). Casings are aluminum with locator tabs that correctly position the light in your 914's headlight mount slots. Lens is polycarbonate plastic with a clear and smooth surface. Low beam is in the top half of the light, high beam in the bottom half (different reflector designs). Low beams use 1.8 A, high beam uses 3.6 A (both top and bottom on). Ad copy says "highway approved for all 50 states", is this true? Who knows. While it says it's for Jeep Wrangler, it fits any standard 7" headlight housing and H4 connector. There is no DRL or "Angel Eye" illumination or connector. https://smile.amazon.com/gp/product/B019I0UBLU The fog/driving lights are "TTX LIGHTING - 4 Inch 27W Round LED Work Light 30 Degree Spot Beam DC 9-75V 2430 Lumens". No idea of if these are DOT approved, take your own risk using these. Actual OD is about 1/8" smaller than the ID of the stock 914 "early" fog light opening. Wires are tinned and stripped, I crimped on spade connectors to connect to the 914's stock fog lamp wiring. They come with a U bracket bottom mount. I attached their mount, then fabricated an adapter using 3/4" x 3/32" zinc-plated steel strip from ACE Hardware. The adapter is 75 mm long, with 90 deg bends at 25 mm and 50 mm (see pics below). Hole positions were determined by test fitting to the car. Beam pattern on these lights is hardly "spot", they're more diffuse, but in actual use in combination with the WHDZ headlights, this is exactly what I wanted, as they fill in the pattern and provide excellent illumination. Casing is aluminum and lens is polycarbonate, light is from an array of LED's. https://smile.amazon.com/gp/product/B00NAR0S20/ Fog/driving light adapter mounted to the stock 914 fog light captive nut, installed in the car. View of the adapter mounted to the fog/driving light Another view of the adapter mounted to the fog/driving light (final hole for mounting to the 914 fog light captive nut not yet drilled in this pic) |
| Spoke |
Sep 28 2016, 10:32 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,419 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
...here's what I bought from them:
Brad, I'm curious why you purchased white LEDs to put behind colored lenses? Much of the light output of the LEDs is filtered out by the red (brake) or amber (turnsignal) lens. The most efficient light output will be realized when the LED color matches the lens color. Also, for the load resistors to keep the OEM flasher happy. Keeping with your "reduce the electrical load" campaign, the load resistors you've added take you right back to the power (21W) of the turnsignal bulbs instead of a nice 2-4W for LEDs. Plus you need to crimp these resistors on existing wiring thus damaging the wire and insulation. Perhaps another path for much lower turnsignal power and no wire crimping is to replace the flasher with EP26 flasher available everywhere. The one issue with EP26 is it doesn't power the 4th terminal needed to power the tach turnsignal indicators. There are easy workarounds for the lack of a powered 4th terminal again requiring no cutting or wire crimping. Attached image(s)
| pbanders |
Sep 28 2016, 10:45 AM
Brad, I'm curious why you purchased white LEDs to put behind colored lenses? Much of the light output of the LEDs is filtered out by the red (brake) or amber (turnsignal) lens. The most efficient light output will be realized when the LED color matches the lens color. Also, for the load resistors to keep the OEM flasher happy. Keeping with your "reduce the electrical load" campaign, the load resistors you've added take you right back to the power (21W) of the turnsignal bulbs instead of a nice 2-4W for LEDs. Plus you need to crimp these resistors on existing wiring thus damaging the wire and insulation. Perhaps another path for much lower turnsignal power and no wire crimping is to replace the flasher with EP26 flasher available everywhere. The one issue with EP26 is it doesn't power the 4th terminal needed to power the tach turnsignal indicators. There are easy workarounds for the lack of a powered 4th terminal again requiring no cutting or wire crimping. I purchased white LED's because the bulbs they replaced were "white" (more like yellow) light. The LED's are very bright, far brighter than stock incandescent lights, even behind the colored lenses. Color looks the same or good enough for me. Not sure I need or want them to be brighter. Turn signals are only on when needed, not in continuous operation. There's no current through the load resistor when they're not being used, so it's not an issue for continuous current draw. The resistors come with inline crimp terminals that penetrate the wiring. Another solution would be to pull the connector at the light and use an inline branch connector. The inline connectors worked fine and were easy to use, I'm not planning on removing them. The EP26 solution is a good idea, but as you point out, has a number of drawbacks. Load resistors were a simpler solution for me. |
pbanders LED's vs Incandescent Lighting Sep 28 2016, 12:12 AM
matthepcat Great write up and thanks for providing actual bef... Sep 28 2016, 12:20 AM
maf914 Thanks for a great write-up and for listing your s... Sep 28 2016, 06:19 AM
Sandy Teener I did the same to my headlights and am super happy... Sep 28 2016, 06:54 AM
Bartlett 914 I recently installed headlights from Vintagecarled... Sep 28 2016, 07:52 AM
pbanders
I recently installed headlights from Vintagecarle... Sep 28 2016, 08:24 AM
pbanders whoops, made accidental double post. Is there any ... Sep 28 2016, 08:26 AM
pbanders I knew I'd forget something. Also buy qty. 2 o... Sep 28 2016, 08:16 AM
N_Jay
I knew I'd forget something. Also buy qty. 2 ... Sep 28 2016, 10:40 AM
timothy_nd28 I also agree with the LED market explosion over th... Sep 28 2016, 08:48 AM
pbanders
I also agree with the LED market explosion over t... Sep 28 2016, 10:36 AM
bandjoey Been waiting for Mikeys headlight bucket rebuild k... Sep 28 2016, 07:46 PM
pbanders My aiming yesterday was seat-of-the-pants, I knew ... Sep 28 2016, 09:50 PM
brownaar Brad,
Did you have any issues with the LED bu... Oct 26 2016, 06:37 PM
pbanders
Brad,
Did you have any issues with the LED b... Oct 26 2016, 09:04 PM
Coondog I am runnng LEDs on everything but my Fogs "p... Oct 26 2016, 08:14 PM
ConeDodger Classic... :first: Oct 27 2016, 04:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th August 2026 - 03:56 AM |
