914 glass butyl, I searched and got confused... |
Kansas 914 |
Sep 28 2016, 08:05 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I am replacing the front and rear glass in the flared car when it gets back from paint.
I have read where the front windshield should use 3/8" butyl, but then there are warnings that this is a tad thick and if you don't have a warm day to press the glass into the butyl the trim won't click in. I think 5/16" inch is a better solution. Does anyone have a source for 5/16" butyl? Does it really matter whether the rear glass is 3/8" or 5/16" since there is no trim just interior pieces? Thanks in advance! |
McMark |
Sep 28 2016, 08:06 AM
ndfrigi |
Sep 28 2016, 08:17 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
McMark, for the rear glass, I believed 3/8 is the original size but I read from few thread here that it is better to use 5/8? I did mine before with 3/8, but after few months I got water leak again. |
McMark |
Sep 28 2016, 08:29 AM
McMark, for the rear glass, I believed 3/8 is the original size but I read from few thread here that it is better to use 5/8? I did mine before with 3/8, but after few months I got water leak again. Rear glass is spec'd at 8mm in the factory manual. So use 5/16" on that as well. Nothing should ever use 5/8" (IMG:style_emoticons/default/unsure.gif) |
ndfrigi |
Sep 28 2016, 09:25 AM
McMark, for the rear glass, I believed 3/8 is the original size but I read from few thread here that it is better to use 5/8? I did mine before with 3/8, but after few months I got water leak again. Rear glass is spec'd at 8mm in the factory manual. So use 5/16" on that as well. Nothing should ever use 5/8" (IMG:style_emoticons/default/unsure.gif) Hi Mike and Mark, For the windshield, when Rufino (from local here who did several 914 windshield) replaced my windshield, he used the gun type sealer and yes it is around 5/16" thick only that he applied and that is installing back the chrome trim. Maybe when i did my rear glass, the 3/8 butyl i bought online (1 box) was old and it didn't stick well. I will check later the box of butyl I have or i didn't do a good job pressing it. |
rick 918-S |
Sep 28 2016, 03:11 PM
Hey nice rack! -Celette Group: Members Posts: 20,494 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
McMark, for the rear glass, I believed 3/8 is the original size but I read from few thread here that it is better to use 5/8? I did mine before with 3/8, but after few months I got water leak again. Rear glass is spec'd at 8mm in the factory manual. So use 5/16" on that as well. Nothing should ever use 5/8" (IMG:style_emoticons/default/unsure.gif) Hi Mike and Mark, For the windshield, when Rufino (from local here who did several 914 windshield) replaced my windshield, he used the gun type sealer and yes it is around 5/16" thick only that he applied and that is installing back the chrome trim. Maybe when i did my rear glass, the 3/8 butyl i bought online (1 box) was old and it didn't stick well. I will check later the box of butyl I have or i didn't do a good job pressing it. I would never use the urethane gun type sealant on the front windshield. if any of it touches the trim you will have to ruin the trim to remove it. As I understand glass installers have to use it on all installs now by law. So get a friend and do it yourself if you can't get the glass company to install as originally designed. |
Kansas 914 |
Sep 28 2016, 03:18 PM
I would never use the urethane gun type sealant on the front windshield. if any of it touches the trim you will have to ruin the trim to remove it. As I understand glass installers have to use it on all installs now by law. So get a friend and do it yourself if you can't get the glass company to install as originally designed. It must vary by state. I had a new windshield installed in the Raspberry car a month ago and he used butyl. He said he hadn't used it in many years but if that is what originally came with the car he could do it. |
Lo-Fi Version | Time is now: 11th June 2024 - 11:37 AM |
