| Joe Owensby |
Mar 30 2010, 10:14 PM
JoeO ![]() ![]() ![]() Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Here are some photos of my trailer hitch, along with some of my kayak carrier. My hobby is whitewater kayaking in the NC and Tn mountains. With this setup, I can enjoy the drive to the rivers as well as the time spent on the rivers. I made a 1 1/4" tubular hitch receiverfor a trailer hitch. This can hold a trailer ball, a bike rack, or the rig I show to hold up the back of the kayaks. The reciever is supported on the rear by the two bars that I bent up to hug the rear of the car, and go beneath the bumper. These are shown in the photo. The inside of the tube is welded to a 2" by 1/2" inch bar that I heated and bent to follow the underside of the trunk up to the point below the center trunk reinforcement, where I have it bolted through the trunk floor. I cut a notch in the sheet metal heat shield for the muffler to allow this bar to hug the trunk floor. This bar then easily clears a stock muffler, tranny, etc. I notched out the back valence to clear the receiver tube. For the front kayak support, I made two aluminum receiver blocks that bolt into the existing tapped holes under the roll bar. These blocks have a notch cut into them that accepts a 3/4 inch square tubular element which is held in place by a simple quick lock 1/4 inch pin. I leave the blocks on all the time. The pins are pulled to allow the crossbar to be simply removed. Works great, carrying up to two kayaks. I was curious to see if the wind from trucks, etc. would cause any problems when I was going down the road at 70 or so. But, no problems. JoeO |
| 914forme |
Sep 29 2016, 06:57 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
Nope, put a hole in the bulk head for my current build.
Before that I did one that bolted into the bulkhead and came out under the bumper, had a bar that went back t the exhaust hanger on the trans. Don't think I have pictures of it. Pretty easy you can thread a 1/4" steel behind there, I did not run a rear valance with this setup. Towed great, with my tire trailer. |
| stevegm |
Sep 29 2016, 07:06 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States
Nope, put a hole in the bulk head for my current build. Before that I did one that bolted into the bulkhead and came out under the bumper, had a bar that went back t the exhaust hanger on the trans. Don't think I have pictures of it. Pretty easy you can thread a 1/4" steel behind there, I did not run a rear valance with this setup. Towed great, with my tire trailer. Did that previous set up work well? How heavy a trailer did you tow with it? |
| 914forme |
Sep 29 2016, 07:17 PM
Nope, put a hole in the bulk head for my current build. Before that I did one that bolted into the bulkhead and came out under the bumper, had a bar that went back t the exhaust hanger on the trans. Don't think I have pictures of it. Pretty easy you can thread a 1/4" steel behind there, I did not run a rear valance with this setup. Towed great, with my tire trailer. Did that previous set up work well? How heavy a trailer did you tow with it? Worked very well, towed all over Ohio with it going to auto-x. Maybe 400 pounds with trailer, tools, jack, tires and wheels, and beverages. Towed like it was not there, the key is taking the load back to a point that can handle it. Tongue weight was next to nothing babe 75 pounds. I also ran all LED lights, and you will need a light combiner. I just flipped the 4 pole out of the trunk, and closed the lid on them, never had an issue. Get to the paddock, drop the trailer switch wheels, and (IMG:style_emoticons/default/driving.gif) BTW, the tool storage bin, doubled as a cooler for the local cruise in. Fill it with ice and drinks, and your set (IMG:style_emoticons/default/beerchug.gif) |
Joe Owensby My Trailer Hitch Receiver Mar 30 2010, 10:14 PM
Joe Owensby Other photos. Note in the rear view that the rea... Mar 30 2010, 10:17 PM
arkitect Pretty cool setup. Never thought I'd see a tra... Mar 30 2010, 11:21 PM
jt914-6 Nice setup...I see you are using the "ski rac... Mar 31 2010, 06:12 AM
Garold Shaffer Nice setup. Like the color of the 914 also. :trop... Mar 31 2010, 07:00 AM
RobW Both are friggen awesome! Nice work! Mar 31 2010, 09:45 AM
zymurgist
:a... Mar 31 2010, 09:55 AM
KELTY360 Nice work. I like that you can still take the top ... Mar 31 2010, 10:46 AM
RobW
Nice work. I like that you can still take the top... Mar 31 2010, 11:55 AM
KELTY360
Nice work. I like that you can still take the to... Mar 31 2010, 12:45 PM
RobW
[quote name='RobW' post='1295004' date='Mar 31 20... Mar 31 2010, 05:40 PM
KELTY360
[quote name='RobW' post='1295004' date='Mar 31 2... Mar 31 2010, 07:27 PM
RobW
[quote name='RobW' post='1295202' date='Mar 31 20... Apr 12 2010, 08:48 AM
carr914 I used to put my Kayak on my trailer - Now I just ... Mar 31 2010, 12:31 PM
Joe Owensby I seriously considered doing what Garold did, ie u... Mar 31 2010, 04:10 PM
1968Cayman Somebody post a pic of a 914 roof-mounted 17 ft. P... Mar 31 2010, 07:18 PM
JTarver
Somebody post a pic of a 914 roof-mounted 17 ft. ... Apr 11 2010, 11:01 PM
Rico Suave I had a tube monted in the trunk of the old ... Apr 12 2010, 09:05 AM
stevegm These pictures are very helpful. I have a slightly... Sep 29 2016, 06:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 03:34 AM |
