priming new fuel pump to injectors |
surfdogskier |
Sep 28 2016, 06:04 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
So I just installed a new electronic fuel pump. All lines got drained when I took the old one off. How do you go about primeing those lines with fuel. I can crank it with starting fluid but there is no gas getting to the injectors and it will eventually shut down. Is there a trick to it?....Thanks in advance.
surfdogskier |
Sep 30 2016, 03:15 PM
I ended up switching the leads on the pump and now it is pumping fuel up the lines. Just not getting it to start yet. Tried cycling the switch like was mentioned earlier but no go yet. Had some gas lines that were leaking so I replaced those. I do see my injectors and connections are filthy. Any threads on cleaning these someone can point me too?
Lo-Fi Version | Time is now: 7th June 2024 - 01:55 PM |
