Wyvern |
Member ![]() ![]() Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California ![]() |
I am working on a 73 1.7
Valves adjusted to spec Points set using dwell Timing on the nose at 27' @ 3500 rpm (vac lines plugged) She runs fairly well. had lots of ping on a up hill. I could rev through it ... More ping as revs drop under load. Today I put in fresh 91 octane and 16oz of seafoam, took a nice drive up a mountain. Almost all the ping is gone. Should I retard the timing just a bit ? Or other suggestions / input much appreciated. |
Wyvern |
Thank you for input.
It is stock FI (D jet) I have not done a compression check . So do understand that is an unknown . I will try seafoam again next tank . & have used water years ago with other vehicles , may try that to help clean . Next would be to then check the dizzy out Now at least I have some ideas and a few things to try. |
Lo-Fi Version | Time is now: 4th July 2025 - 07:54 PM |
