Lost Power, No Fuel, Help! |
Nogoodwithusernames |
Sep 28 2016, 01:57 PM
Member Group: Members Posts: 239 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
So I got all the fuel lines replaced and it's been running splendidly, decided to take it to work today. Just a minute away from work it would die at idle after the 30minute fwy run, but I got it re-started and got to work just keeping the throttle open a bit when stopped.
I had to run an errand and started to get onto the freeway again and lost all power. Pulled over, opened the decklid and much to my dismay one of the fuel lines had popped off the right side fuel rail. I attached and tightened all the lines/clamps outside the car so it wasn't loose but it's back on and nice and tight again. Tried to start it and nothing, cycle the pump a few times and crank. Nothing. It tried to start a few times but wouldn't run. Got it towed back to work and I've checked a few things when I've had time. There is fuel in the lines still, but I don't seem to be getting anything from the injectors. At least on the driver side where I pulled them out of the manifold. I did play with the connector on the distributor and it seems to be well seated, as do the connections on the injectors. I can't imagine that all four injectors would get clogged at the exact same time either, just seems a bit implausible. I don't see how losing fuel pressure would then keep the injectors from firing but anyone have any ideas? |
jcd914 |
Oct 1 2016, 02:23 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I know it is a dumb question but is there fuel in the tank?
When I worked at a shop (almost 20 years) we often had cars towed in because they died or won't start, only to find they were out of gas. When your line came loose did you lose all the fuel? Do you have fuel in the fuel line at the fuel pump? Where your pump is located fuel should flow via gravity to your fuel pump, so you you pull the line off the pump fuel should start flowing out (usually running down your arm and to your arm pit). Jim |
Oct 1 2016, 02:42 PM
I know it is a dumb question but is there fuel in the tank? When I worked at a shop (almost 20 years) we often had cars towed in because they died or won't start, only to find they were out of gas. When your line came loose did you lose all the fuel? Do you have fuel in the fuel line at the fuel pump? Where your pump is located fuel should flow via gravity to your fuel pump, so you you pull the line off the pump fuel should start flowing out (usually running down your arm and to your arm pit). Jim Haha yep there's definitely fuel, I'd be pretty embarrassed if I did that! Got about a half tank and the return line puts out enough pressure to run the engine so I could pull it around into the shop the other day. I'll probably just put in the inline E2000 pump I've got in the garage from my "test stand" to get me by for now. Don't know that I wanna drop $400 on a rebuilt unit from AA. |
Lo-Fi Version | Time is now: 7th June 2024 - 02:23 PM |
