> Please help rid me of "ping"
Wyvern
post Sep 30 2016, 08:49 PM
I am working on a 73 1.7
Valves adjusted to spec
Points set using dwell
Timing on the nose at 27' @ 3500 rpm (vac lines plugged)
She runs fairly well. had lots of ping on a up hill.
I could rev through it ... More ping as revs drop under load.
Today I put in fresh 91 octane and 16oz of seafoam, took a nice drive up a mountain.
Almost all the ping is gone.
Should I retard the timing just a bit ?
Or other suggestions / input much appreciated.
injunmort
post Oct 1 2016, 05:17 PM
if you think a de-coking is nessesary, i like the idea of sea foam on a vacuum line rather water. also add sea foam to the gas. still think you must verify correct operation of distributor advance and correct timing.
Wyvern   Please help rid me of "ping"   Sep 30 2016, 08:49 PM
audio_file   Fuel injected or carbs?   Sep 30 2016, 08:58 PM
bdstone914   Any idea of the compression ratio? Yes retard the...   Sep 30 2016, 09:00 PM
injunmort   pinging under load is too much advance, stock dist...   Sep 30 2016, 09:03 PM
76-914   More Sea Foam or try squirting some water in the T...   Sep 30 2016, 09:08 PM
Wyvern   Thank you for input. It is stock FI (D jet) I hav...   Oct 1 2016, 12:09 AM
Perry Kiehl Clone   Make sure the distributor plate in the distributor...   Oct 1 2016, 05:56 AM
veekry9   An extreme technique,filling each cylinder wit...   Oct 1 2016, 06:12 AM
bdstone914   I agree with other to focus on the distributor. I...   Oct 1 2016, 06:27 AM
Mblizzard   Also verify fuel pressure, MPS operation, and abse...   Oct 1 2016, 06:32 AM
r_towle   Lots of carbon build up in the combustion chamber ...   Oct 1 2016, 11:22 AM
mark04usa   Try running Premium fuel :wavebye: .   Oct 1 2016, 03:18 PM
Dominic   Try running Premium fuel :wavebye: . He is, 91 ...   Oct 1 2016, 03:55 PM
ClayPerrine   1. get a normal sized bottle of water. Distilled i...   Oct 1 2016, 04:04 PM
injunmort   if you think a de-coking is nessesary, i like the ...   Oct 1 2016, 05:17 PM
Wyvern   Hello. I rigged a spray bottle the kind you would ...   Oct 3 2016, 03:22 PM
r_towle   Sprayed while driving deserves a picture of the co...   Oct 3 2016, 05:13 PM
Perry Kiehl Clone   Actually premium fuel has more additives, burns sl...   Oct 3 2016, 09:30 PM
- Lo-Fi Version Time is now: 4th July 2025 - 07:46 PM
