The 914 conversion, 3.3 Ltr suby upgrade |
flmont |
Sep 25 2016, 09:58 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
914forme |
Oct 2 2016, 11:52 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Yes the fuel screen, they get crude up, easy enough to check if you need one. All you need is hose, like Chris suggested. And a new fitting for under the tank.
BTW, the small car mount is available as just the mounts - just have to call them. It is what I used on mine. First version as a -4 style using early -4 bar. Second version went to the firewall. Like a Patric Motorsports -6 mount. It is a -6 after all. Makes it easier to get the clearance to put the EG in with out cutting the trunk. Chris did the flipped manifold on his conversion. I had room but never do anything the easy way. :headband: Also you might want to take a die and run it down the outside of the lines. Gives the hose a little something to grab onto. They just have to be roughed up a bit. Most people don't have beading tools to make them proper. (IMG:style_emoticons/default/shades.gif) |
76-914 |
Oct 2 2016, 01:03 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Also you might want to take a die and run it down the outside of the lines. Gives the hose a little something to grab onto. They just have to be roughed up a bit. Most people don't have beading tools to make them proper. (IMG:style_emoticons/default/shades.gif) You can also barely flare the end of the tube in lieu of a bead. Barely being the operative word here. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 22nd May 2024 - 11:58 PM |
