Alternator bracket, broken again. |
Elliot Cannon |
Oct 1 2016, 06:04 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
After the lengthy thread about alternators, I decided I should look into why mine is rattling so badly. This is the second bracket that has broken in less than a year. I was thinking of welding it back together and adding a doubler in the form of a washer or just fabricating a whole new one out of thicker steel. Any ideas why it might have broken in the first place? Is it possible I tightened the belt too tight? Is it possible it is vibrating so much it fatigued the metal?
Attached image(s) |
76-914 |
Oct 2 2016, 12:54 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Couldn't help but notice that the hole was oval. What caused that? Was it loose once?My rule of thumb minimum; the distance between the edge of the bolt hole and the edge of the metal should equal the drilled hole diameter. You've basically corrected that with the washer and the welds resulted in nice filets which will add strength.
BillC |
Oct 3 2016, 07:36 AM
Senior Member Group: Members Posts: 548 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 11th June 2024 - 05:24 AM |
