Alternator bracket, broken again. |
Elliot Cannon |
Oct 1 2016, 06:04 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
After the lengthy thread about alternators, I decided I should look into why mine is rattling so badly. This is the second bracket that has broken in less than a year. I was thinking of welding it back together and adding a doubler in the form of a washer or just fabricating a whole new one out of thicker steel. Any ideas why it might have broken in the first place? Is it possible I tightened the belt too tight? Is it possible it is vibrating so much it fatigued the metal?
Attached image(s) |
McMark |
Oct 2 2016, 11:59 AM
The lower bolt is in place and tight?
All the fan blades are intact? Alternator pulley out of round / bent? Maybe you need to get your belt balanced. (IMG:style_emoticons/default/hide.gif) |
Elliot Cannon |
Oct 2 2016, 03:20 PM
The lower bolt is in place and tight? All the fan blades are intact? Alternator pulley out of round / bent? Maybe you need to get your belt balanced. (IMG:style_emoticons/default/hide.gif) I have an idea that I'll be looking for a new alternator in the future. I have noticed since the repair that the alternator is making a pretty loud whining noise. Maybe a bearing issue. Anyway, if I'm going to install a seat heater in the car, I might need more of them amp things to work with. Till then it's producing 13.8 volts at low rpm. I took my belt into NAPA and they balanced it on their dynamic belt balancing and tension setting machine. You should get one of those for your shop. (IMG:style_emoticons/default/biggrin.gif) |
bdstone914 |
Oct 3 2016, 08:14 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The lower bolt is in place and tight? All the fan blades are intact? Alternator pulley out of round / bent? Maybe you need to get your belt balanced. (IMG:style_emoticons/default/hide.gif) I have an idea that I'll be looking for a new alternator in the future. I have noticed since the repair that the alternator is making a pretty loud whining noise. Maybe a bearing issue. Anyway, if I'm going to install a seat heater in the car, I might need more of them amp things to work with. Till then it's producing 13.8 volts at low rpm. I took my belt into NAPA and they balanced it on their dynamic belt balancing and tension setting machine. You should get one of those for your shop. (IMG:style_emoticons/default/biggrin.gif) I can get ine of my spare alternators rebuilt at a local shop. They charge me $75. I need 25 for the core. Commercial rebuilds are crap and hard to find. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:38 PM |
