Clutch Slips on 6 conversion |
Catorse |
Oct 2 2016, 03:16 PM
Member Group: Members Posts: 194 Joined: 27-August 15 From: Los Angeles Member No.: 19,106 Region Association: Southwest Region |
So here's the deal:
- built 2.7 with Webers. All the tricks possible on this motor - rebuilt trans - new flywheel (not resurfaced!) - new 914 clutch - New TOB - new clutch cable Cable is adjusted so that engagement point is as close to the floor as possible. When I go above 4000 RPM, I get some serious clutch slip. So bad I can't really climb higher, although the car has a 7K limit. I'm thinking the stock 914 clutch can't hold it, even though it is a brand new clutch. Any ideas here? I do not believe it is making enough power to overwhelm the stock clutch, unless the stock clutch is super weak. |
sixnotfour |
Oct 3 2016, 02:24 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
adjust your clutch |
Catorse |
Oct 3 2016, 09:58 AM
OK, so basically this means 1" of pedal travel before the clutch engages? Is that what we are talking about here, because that is what it is set at currently. |
TheCabinetmaker |
Oct 4 2016, 02:49 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
OK, so basically this means 1" of pedal travel before the clutch engages? Is that what we are talking about here, because that is what it is set at currently. Don't want to read you wrong. Are you asking if the clutch should engage 1" from when you push on the pedal? |
Lo-Fi Version | Time is now: 9th June 2024 - 10:46 AM |
