L-Jet TPS is all oily, the bottom of the Throttle Body etc.... |
malcolm2 |
Oct 3 2016, 08:43 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Taking the TB off to be rebuilt and could not help but notice that the under side is covered with oily dirt. 20,000 miles since I put it all together, but this area has, by far, the worst build up.
The boot seems pretty stiff but no obvious cracks of holes. 1. I assume the oil is coming from the oil tower filler neck. But why would it blow out with air sucking in? 1st thought the stiff boot did not make a good seal and this is my vacuum leak. But again shouldn't it suck in? But the btm clamp screw on the boot was very tight. 2. is this normal? 3. are the "S" boots available new? |
Rob-O |
Oct 5 2016, 08:36 AM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
The 2.0L is just #2. It doesn't use the cap as a PCV. Instead it has vents on the heads and or a PCV like device on the base of the filler neck assembly (#7 in the diagram above).
malcolm2 |
Oct 5 2016, 12:03 PM
The 2.0L is just #2. It doesn't use the cap as a PCV. Instead it has vents on the heads and or a PCV like device on the base of the filler neck assembly (#7 in the diagram above). So #7 assembly would be both 1.8 and 2.0? I have never paid attention to what the btm of my filler box looks like. But Blizzard could be right. I sure don't remember a PCV device bolted to the btm. |
Mblizzard |
Oct 5 2016, 12:12 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
The 2.0L is just #2. It doesn't use the cap as a PCV. Instead it has vents on the heads and or a PCV like device on the base of the filler neck assembly (#7 in the diagram above). So #7 assembly would be both 1.8 and 2.0? I have never paid attention to what the btm of my filler box looks like. But Blizzard could be right. I sure don't remember a PCV device bolted to the btm. I think I have a 1.8 #7 assembly at home. I can check tonight if someone else does not beat me to it. But I seem to remember something being there. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:18 AM |
