Brian Mifsud |
Mechanical Engineer ![]() ![]() ![]() Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None ![]() |
Has anyone successfully swapped in a Subaru and NOT had to slice up the body for the cooling lines, plumbing, and heat exchangers?
Specifically, in the nose of the car, can you get adequate cooling by installing the radiator and ducting by slicing up/altering JUST the front hood? (inlet in front, outlet at base of windshield, or above fender wells). I'd like to make the swap wholly reversible so the car keeps it's "Stock" value. "Plan B" (very undesirable) I'd think would be to cut out the inner fender wells, but keep the steel to reweld later.. and use the front hood (glass replica) to do the air-inlet. |
zipedadoo |
Member ![]() ![]() Group: Members Posts: 135 Joined: 23-January 14 From: Arizona Member No.: 16,921 Region Association: None ![]() |
I put a stock 2.2 subaru engine and transmission in a 1972 914.
The radiator is in the engine compartment with a under body scoop. My son has been driving for over a year and the temp stays at 190 and he has yet to drag the scoop off. All the mods I did could be reversed in a afternoon. Except the fuel tank and the heater core setup. But you don't have to cut the tank and the heater core could stay in place I guess. My biggest problem would be storing and not losing all the stock parts. |
Lo-Fi Version | Time is now: 14th July 2025 - 04:07 AM |
