> Subaru Conversion.. Is it Reversible?, Want to keep body stock.
Brian Mifsud
post Oct 6 2016, 11:35 AM
Mechanical Engineer
Has anyone successfully swapped in a Subaru and NOT had to slice up the body for the cooling lines, plumbing, and heat exchangers?
Specifically, in the nose of the car, can you get adequate cooling by installing the radiator and ducting by slicing up/altering JUST the front hood? (inlet in front, outlet at base of windshield, or above fender wells).
I'd like to make the swap wholly reversible so the car keeps it's "Stock" value.
"Plan B" (very undesirable) I'd think would be to cut out the inner fender wells, but keep the steel to reweld later.. and use the front hood (glass replica) to do the air-inlet.
Brian Mifsud
post Oct 6 2016, 03:26 PM
Mechanical Engineer
The "Subie Conversions" I've seen in the flesh were cars that ALSO had been restored. They were impressive to say the least, but I'm a Mechanical Engineer so I'm tuned in to things like that and have an appreciation for jobs well done. The "irrational" part of me is for some reason is MORE impressed by a fully restored air-cooled car. I guess that just fits into my wholly VW "Roots" as I've read everything that can be found on the history of VW and Porsche.
When it's time to sell my car, that's when I'd rather it be dead stock.
I have a '76 2.0 that's fully intact and original down to functioning SMOG equipment. It's the heaviest 914 with lowest horsepower.. an underdogs amongst underdogs. When I was young and poor (instead of old and poor), I couldn't afford a '73-'74 2.0 that was in as good a condition as this car.
A modified air-cooled motor really means I need to maintain a second engine as I still need to meet California smog every 2 years and wouldn't want to split a crankcase to swap out cams, fuel injection etc. If I'm going to have to drop the engine every two years ( I used to do this with my hot-rod Beetles, keeping a dead stock 1.6 stored in the garage), I might as well drop in a high performer one when not at the inspection station (which no 914 engine will ever be for reasonable money.. I don't make "Raby" money....)
If it can be made to work WELL, a Subie engine with "onboard" cooling system would make life much easier when it came to dropping and swapping. Besides, I design machinery for a living, so this is the sort of challenge I call "Fun" (yes I'm sick that way).
Brian Mifsud   Subaru Conversion.. Is it Reversible?   Oct 6 2016, 11:35 AM
iwanta914-6   If you are concerned about "stock value...   Oct 6 2016, 11:40 AM
Brian Mifsud   If you are concerned about "stock value...   Oct 6 2016, 11:50 AM
Mueller   If you are concerned about "stock value...   Oct 6 2016, 11:50 AM
Andyrew   A 2056 motor seems like it would work much better ...   Oct 6 2016, 11:53 AM
Brian Mifsud   A 2056 motor seems like it would work much better...   Oct 6 2016, 12:13 PM
mepstein   A compromise car won't be good as a conversion...   Oct 6 2016, 01:56 PM
DBCooper   Yes, it can be done so it's easily reversible,...   Oct 6 2016, 02:49 PM
zipedadoo   I put a stock 2.2 subaru engine and transmission i...   Oct 6 2016, 03:21 PM
Brian Mifsud   I put a stock 2.2 subaru engine and transmission ...   Oct 6 2016, 03:27 PM
JmuRiz   I put a stock 2.2 subaru engine and transmission ...   Oct 6 2016, 08:03 PM
Brian Mifsud   The "Subie Conversions" I've seen in...   Oct 6 2016, 03:26 PM
76-914   I've got to agree w/ DB. I went out of my way ...   Oct 6 2016, 03:34 PM
DBCooper   Hey Brian, Penngrove? I lived there when going to...   Oct 6 2016, 06:00 PM
Brian Mifsud   Hey Brian, Penngrove? I lived there when going t...   Oct 7 2016, 09:18 AM
Mike Bellis   All in or all out... Make up your mind.   Oct 6 2016, 07:02 PM
Mike Bellis   on a 76 that means swapping fuel tanks, EVAP, gas ...   Oct 7 2016, 10:40 PM
RobW   Its easily switchable..... for sale.   Oct 8 2016, 12:00 AM
- Lo-Fi Version Time is now: 14th July 2025 - 04:25 AM
