> Subaru Conversion.. Is it Reversible?, Want to keep body stock.
Brian Mifsud
post Oct 6 2016, 11:35 AM
Mechanical Engineer
Has anyone successfully swapped in a Subaru and NOT had to slice up the body for the cooling lines, plumbing, and heat exchangers?
Specifically, in the nose of the car, can you get adequate cooling by installing the radiator and ducting by slicing up/altering JUST the front hood? (inlet in front, outlet at base of windshield, or above fender wells).
I'd like to make the swap wholly reversible so the car keeps it's "Stock" value.
"Plan B" (very undesirable) I'd think would be to cut out the inner fender wells, but keep the steel to reweld later.. and use the front hood (glass replica) to do the air-inlet.
Mike Bellis
post Oct 6 2016, 07:02 PM
Resident Electrician
All in or all out...
Make up your mind.
Brian Mifsud   Subaru Conversion.. Is it Reversible?   Oct 6 2016, 11:35 AM
iwanta914-6   If you are concerned about "stock value...   Oct 6 2016, 11:40 AM
Brian Mifsud   If you are concerned about "stock value...   Oct 6 2016, 11:50 AM
Mueller   If you are concerned about "stock value...   Oct 6 2016, 11:50 AM
Andyrew   A 2056 motor seems like it would work much better ...   Oct 6 2016, 11:53 AM
Brian Mifsud   A 2056 motor seems like it would work much better...   Oct 6 2016, 12:13 PM
mepstein   A compromise car won't be good as a conversion...   Oct 6 2016, 01:56 PM
DBCooper   Yes, it can be done so it's easily reversible,...   Oct 6 2016, 02:49 PM
zipedadoo   I put a stock 2.2 subaru engine and transmission i...   Oct 6 2016, 03:21 PM
Brian Mifsud   I put a stock 2.2 subaru engine and transmission ...   Oct 6 2016, 03:27 PM
JmuRiz   I put a stock 2.2 subaru engine and transmission ...   Oct 6 2016, 08:03 PM
Brian Mifsud   The "Subie Conversions" I've seen in...   Oct 6 2016, 03:26 PM
76-914   I've got to agree w/ DB. I went out of my way ...   Oct 6 2016, 03:34 PM
DBCooper   Hey Brian, Penngrove? I lived there when going to...   Oct 6 2016, 06:00 PM
Brian Mifsud   Hey Brian, Penngrove? I lived there when going t...   Oct 7 2016, 09:18 AM
Mike Bellis   All in or all out... Make up your mind.   Oct 6 2016, 07:02 PM
Mike Bellis   on a 76 that means swapping fuel tanks, EVAP, gas ...   Oct 7 2016, 10:40 PM
RobW   Its easily switchable..... for sale.   Oct 8 2016, 12:00 AM
- Lo-Fi Version Time is now: 14th July 2025 - 04:20 AM
