Brian Mifsud |
Mechanical Engineer ![]() ![]() ![]() Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None ![]() |
Has anyone successfully swapped in a Subaru and NOT had to slice up the body for the cooling lines, plumbing, and heat exchangers?
Specifically, in the nose of the car, can you get adequate cooling by installing the radiator and ducting by slicing up/altering JUST the front hood? (inlet in front, outlet at base of windshield, or above fender wells). I'd like to make the swap wholly reversible so the car keeps it's "Stock" value. "Plan B" (very undesirable) I'd think would be to cut out the inner fender wells, but keep the steel to reweld later.. and use the front hood (glass replica) to do the air-inlet. |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Its easily switchable..... for sale.
Lo-Fi Version | Time is now: 14th July 2025 - 04:20 AM |
