Considering the removal of the oil pressure gauge, I have given up |
914Bryan |
Oct 6 2016, 09:11 AM
Member Group: Members Posts: 190 Joined: 6-June 11 From: Orange County Member No.: 13,162 Region Association: Southern California |
Please tell me that there are some of you that have battled the same oil pressure issue I have? After my 2256 build, ditching all the stock 2.0 FI and its components and moving to carburetors, I have enjoyed a moderately powerful, fun car to drive. It is a real blast and the money was not wasted. I am happy with how it runs.
The issue is the wild fluctuation of oil pressure that I can't help but watch. I feel like a moth to a light. Some examples: Yesterday, idling in rush hour stop and go traffic, it was always about 10 lbs over whatever thousand rpm the engine was at (example, 3,000=40lbs). This is where I like to see it. That night, during the same drive, but without stop and go traffic, it was about 10-20lb below whatever thousand rpm it was at. When stopping and making a left turn, the oil pressure warning light kept coming on. Today, mid 60 weather, drove it about 20 minutes, and the oil pressure never went below 50, even at idle. There is other craziness and inconsistency, cold or hot engine, outside temperature, does not matter, and i am sure you get the picture. WTF? Oil level is always checked and I overfill it about a 1/4 to 1/2 quart. As far as I know the oil system is stock with a 30mm Melling aluminum pump. Brand new electronic VDO gauge and sending unit. I want to say F**k it, disconnect the gauge and throw caution to the wind, but I just cant bring myself to doing it. Please, any ideas of what I can do to solve this or where to start looking? |
iankarr |
Oct 10 2016, 12:06 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The port on the engine is M10, which is close but not exactly the same threading as NPT. There's been lots of disagreement on using an NPT hose and the case to me is pretty clear that it's best to stick with M10. The hose in this kit is designed for type IV engines...so the hose is natively M10. No adapter or bushing needed. The remote block has both NPT and M10 ports, which allow you to mix senders as needed.
Lo-Fi Version | Time is now: 6th June 2024 - 09:30 PM |
