> Install battery stand and tray, Recommendations
watsonrx13
post Oct 13 2004, 04:01 PM
Since I had to search extensively for the installation of a battery stand and tray, I decided to write up the process that I used to weld in my new one.
This 'upgrade'/'enhancement' to the 914 is probably the easiest welding project that I've done yet. I replaced mine because I was replacing the suspension ear and engine shelf and the battery tray was starting to show signs of rust. It also allowed me to check the frame rail underneath.
Here's the before shot. It doesn't look as bad as others, but I wanted to do it 'right' since I was in there.
watsonrx13
post Oct 17 2004, 03:54 PM
Finally, here's a shot of an old battery that I put in place to verify the position and the strength of the welds.
This is a very straight forward welding project that anyone can do, just remember, take your time. I probably spent 10x the amount of time fitting and/or grinding as I did welding.
I hope your project turns out as well as mine. Good luck.
watsonrx13   Install battery stand and tray   Oct 13 2004, 04:01 PM
watsonrx13   I'm not going to show the removal process as i...   Oct 13 2004, 04:02 PM
watsonrx13   The first thing you'll need to do is bolt the ...   Oct 13 2004, 04:02 PM
watsonrx13   Here's a section that I'll remove to make ...   Oct 17 2004, 03:51 PM
watsonrx13   Next, I removed the stand and tray and painted the...   Oct 17 2004, 03:51 PM
watsonrx13   Next, I removed the paint where I will be welding ...   Oct 17 2004, 03:51 PM
watsonrx13   Now I ready to begin welding. I bolted the two pie...   Oct 17 2004, 03:52 PM
watsonrx13   Next, I removed the bolt and the tray to be able t...   Oct 17 2004, 03:52 PM
watsonrx13   Now comes the final welding of the tray. I bolted ...   Oct 17 2004, 03:53 PM
watsonrx13   The final welding was done on the top. I welded th...   Oct 17 2004, 03:53 PM
watsonrx13   Here's my completed engine compartment improve...   Oct 17 2004, 03:53 PM
watsonrx13   Finally, here's a shot of an old battery that ...   Oct 17 2004, 03:54 PM
type47   i haven't done this myself, but a shop did it ...   Oct 17 2004, 03:59 PM
dinomium   If I can get off the couch today, I just might go ...   Oct 17 2004, 05:28 PM
double-a   thanks for the great step-by-step! it's es...   Oct 17 2004, 05:32 PM
URY914   Rob, I think people would be intrested to know th...   Oct 18 2004, 07:10 AM
watsonrx13   Thanks Paul for the compliment, especially coming ...   Oct 18 2004, 10:02 AM
i love porsche   looks great! i think im just going to relocat...   Oct 18 2004, 12:53 PM
Lou W   Thanks for all the info, I've been down loadin...   Oct 18 2004, 01:16 PM
Root_Werks
- Lo-Fi Version Time is now: 5th July 2025 - 12:08 AM
