Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
HAM Inc |
Oct 19 2016, 02:44 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Hate to spoil the Wasser fun, but... check the bore center. IIRC it's closer to the T1, which is waaay off from the T4. Not to mention the lifter spacing is off.
It will definitely not be an off the shelf deal. Nowhere near plug and play, even if the exhaust ports can be opened enough (and I don't think they can, but could be wrong) to support a 80+% ex/in flow ratio where intakes are moving in the ballpark of 180-200cfm at .5 lift, which I suspect you'll require for 175hp/l IMO, you need to keep looking. Len |
Mueller |
Oct 19 2016, 03:03 PM
Hate to spoil the Wasser fun, but... check the bore center. IIRC it's closer to the T1, which is waaay off from the T4. Not to mention the lifter spacing is off. It will definitely not be an off the shelf deal. Nowhere near plug and play, even if the exhaust ports can be opened enough (and I don't think they can, but could be wrong) to support a 80+% ex/in flow ratio where intakes are moving in the ballpark of 180-200cfm at .5 lift, which I suspect you'll require for 175hp/l IMO, you need to keep looking. Len Bummer, reality always getting in the way.... I figured it was too good to be true, I did find someone running those heads on a type I... http://www.shoptalkforums.com/viewtopic.ph...37&t=141797 |
Lo-Fi Version | Time is now: 5th June 2024 - 03:13 AM |
