Weber carb set up help, Jetting seemed to help but still slight popping/backfire |
North Coast Jim |
Oct 20 2016, 09:33 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Just finished a new 2 liter engine build with Webcam for carbs installed.
New Raby heads, Hoffman Eng, are used. New 44IDF Webers installed with cross bar linkage. Valve lash to spec and timing is spot on. Carbs are synched. Continue to hear a slight popping from only the pass side carb at partial throttle positions. Car starts and idles with plenty of power thru acceleration, but who knows I haven't driven one in over 25 years. It's a hoot to drive except for the Issue. Played with jetting to no avail. Any Carb guru's out there able to provide input to solve this dilemma. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/confused24.gif) |
Elliot Cannon |
Oct 20 2016, 10:52 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
To make sure mine opened all the way to WOT and opened at the same rate, I had my wife push down on the pedal while I watched the butterflies move. When nothing moved at all, I realized she was pushing on the brake pedal. (IMG:style_emoticons/default/confused24.gif) I guess it was my fault. I told her to slowly push down on the pedal on the "right". (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 3rd June 2024 - 06:39 AM |
