Rough cylinder walls, What can be the cause? |
HansJan |
Oct 19 2016, 09:28 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
Today the shop had taken the engine out of the car, just to replace the very stiff valve springs. When the heads came off we noticed that there are rough areas on the cylinder walls. Not everywhere, but at least two areas per cylinder. FYI: Cylinders are 103.8 mm (by AA). Pistons are also by AA. Markings on cam: CWC Valves Intake: 44.35 mm Valve Exhaust: 38 mm My question to the brain-trust is: What could be the cause for the rough areas? Some back ground info: This car supposed to have "Nickies" Cylinders and JE-Pistons. Obviously the (Craigslist) seller and I are no friends. After receiving it, I drove the car for less then 10 minutes before the car caught on fire. |
injunmort |
Oct 21 2016, 11:59 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
my apologies worn, i misunderstood the question. i dont think diameter would cause these marks, i have seen this in motorcycle engines when a wrist pin clip is not installed. when the engine gets to operating temp the wrist pin will bounce in and out of the piston contacting the cylinder wall. it will mangle the cylinder if left unattended.
HansJan |
Oct 22 2016, 10:46 AM
my apologies worn, i misunderstood the question. i dont think diameter would cause these marks, i have seen this in motorcycle engines when a wrist pin clip is not installed. when the engine gets to operating temp the wrist pin will bounce in and out of the piston contacting the cylinder wall. it will mangle the cylinder if left unattended. Oh my GOD. That would be a disaster. Will call the shop first thing on Monday to check. Thanks guys. |
Lo-Fi Version | Time is now: 16th June 2024 - 10:08 AM |
