BUILD-OFF CHALLENGE: Tygaboy's '75 LS3, It seemed a good idea at the time... |
tygaboy |
Oct 17 2016, 10:56 AM
914 Guru Group: Members Posts: 5,307 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Hi World!
Let the games begin! (IMG:style_emoticons/default/piratenanner.gif) As the title says, it's a '75 that's getting an LS3 (Cracker's "old" motor - thanks Tony!) and Boxster 6 speed. Also planned is zippidy doo-dah 911 front suspension with Boxster calipers all around. The rear suspension is getting 911 ebrakes, Tangerine Racing raised pickups and shock towers. I have plans to stiffen the chassis with a partial cage. Doesn't that sound like a great plan? I think so, too! BACKGROUND: I got this as a roller that was purported to be "dry and accident free". And it was! Except for all the rust and the place where it was hit. Yeah, yeah... But it's all good. The seller and I worked everything out. (IMG:style_emoticons/default/beerchug.gif) But our little 914s are full of surprises and isn't that half the fun? So, first up is rust repair time! (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/welder.gif) Let's begin with some pics of what I started with. Wish me luck! Wait, forget the luck, wish me SKILL!!! Attached image(s) |
914forme |
Oct 23 2016, 09:48 AM
Very nice bar tuck. If your not planning on running anything up the logs, cut a slit in the lower rear firewall, and extend stiffing all the way from the front to the rear suspension console.
I would also highly recommend 914 LTD outer log kit. Brad's kit will make your car stiff, runs from the front log all the way back to the rear suspension console. I can jack inside of my car up and the back, and lift three tires off the ground. It also only twists about 1/8" That was with a Roll bar, and petty bar installed. Have not tried it with out the roll bar and petty bar. You could also go full steel top, or bolt down your fiberglass top, and add re-enforcments to that to to help out. I checked a 944 out, 18ga metal, and very similar design to the 914 A-pilars. though the Gas had a re-enforcment added to the lower A-pilars. You can also build a box section going down the center of the chassis. Think Lotus back bone, very strong, and can be made very light. You are on a very slippery slope. BTW, LS3 excellent choice (IMG:style_emoticons/default/aktion035.gif) |
tygaboy |
Oct 23 2016, 01:25 PM
Very nice bar tuck. If your not planning on running anything up the logs, cut a slit in the lower rear firewall, and extend stiffing all the way from the front to the rear suspension console. I would also highly recommend 914 LTD outer log kit. Brad's kit will make your car stiff, runs from the front log all the way back to the rear suspension console. I can jack inside of my car up and the back, and lift three tires off the ground. It also only twists about 1/8" That was with a Roll bar, and petty bar installed. Have not tried it with out the roll bar and petty bar. You could also go full steel top, or bolt down your fiberglass top, and add re-enforcments to that to to help out. I checked a 944 out, 18ga metal, and very similar design to the 914 A-pilars. though the Gas had a re-enforcment added to the lower A-pilars. You can also build a box section going down the center of the chassis. Think Lotus back bone, very strong, and can be made very light. You are on a very slippery slope. BTW, LS3 excellent choice (IMG:style_emoticons/default/aktion035.gif) You're stealing my thunder! The plan is to remove the stock tunnel and build a taller tunnel structure. I want to get the Boxster shift lever up nearer the steering wheel so kill two birds... And I already have the 914 Ltd kit but not sure I'll need it with the inner long stiffening and the stiffening cage. We'll see. I can always add it later. |
Lo-Fi Version | Time is now: 6th June 2024 - 10:17 PM |
