Turbocharging a type 4 |
stownsen914 |
Oct 12 2016, 02:04 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I have heard the conventional wisdom that "you can't turbocharge a type 4 successfully." Is it just difficult, or can it really not be done well? I'm tossing around the crazy idea of turbo'ing a type 4 for PCA club racing, to put in the chassis in my avatar. My 6 in its current configuration is not competitive, so I can put a bunch of money in that, or do something different. I like a challenge, so why wouldn't the following work?
- 1.8 or 2.0 type 4 as a base. I would keep displacement stock or close to it. - EFI for induction - Properly sized intercooler and huge oil cooler - A good aftermarket cooling fan - Would be dry sumped - I would work with a knowledgeable builder or shop to build the engine. I am not so familiar with type 4 race modifications, but presumably this would include reinforcing the bottom end, using Carrillo, Pauter, etc. rods - Obviously the heads would need to be reworked for flow and possibly reliability If I do the above, could a type 4 be built to withstand 15 psi of boost and make 350 hp reliably? Scott |
HAM Inc |
Oct 21 2016, 08:15 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
I have a customer who does vintage racing with a NA 914/4 in TX. He regularly runs on track temps exceeding 130F.
He recently reported that he rigged a nozzle that draws water from his cool suit cooler and squirts it in the fan. Says he does it about half way through his 40 minute races when CHT's start creeping up, and a time or two in the second half of the race. Says it uses about a 2 quarts of water and CHT's drop 30* or so. |
ottox914 |
Oct 24 2016, 05:42 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
I have a customer who does vintage racing with a NA 914/4 in TX. He regularly runs on track temps exceeding 130F. He recently reported that he rigged a nozzle that draws water from his cool suit cooler and squirts it in the fan. Says he does it about half way through his 40 minute races when CHT's start creeping up, and a time or two in the second half of the race. Says it uses about a 2 quarts of water and CHT's drop 30* or so. It'd be interesting to see about the CHT's for each hole- as much as there is not equal cooling via the air from the fan, I'm having a hard time with equal cooling from the water. He's shown it works- But you'd hate to think you were fine, and have one cylinder be a couple hundred degrees over the others. Does he run a 4 x 4 system with an EGT and CHT for each cylinder? That would be some interesting data to see. |
Lo-Fi Version | Time is now: 31st May 2024 - 08:49 PM |
