Are head and cylinder gaskets compression gaskets? |
stevegm |
Oct 22 2016, 01:04 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
I need to remove the heads off of a newly rebuilt engine (4-cylinder) I built (never run). They have already been torqued. Are the head gaskets and gasket between the cylinder and block, compression gaskets that should be thrown away (i.e., replaced with new one) after I untorque the heads?
The head gaskets will be easy to replace. But I'd have to pull the cylinders to replace the ones between them and the block. |
injunmort |
Oct 26 2016, 04:51 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
^that makes sense to me, in that the the exhaust side runs much hotter, (hence, the the sodium filled exhaust valves or nmeumonic exhaust valves, to disisapate heat more efficiently reside.) if the deformation was in that area, the exhaust stroke will reek the havok you see by a faulty seal. but iam sure HAM,INC, has a well reasoned explanation as to why i am full of shit and you need a set of new $2,000.00 heads.
6 |
Mark Henry |
Oct 27 2016, 07:42 AM
^that makes sense to me, in that the the exhaust side runs much hotter, (hence, the the sodium filled exhaust valves or nmeumonic exhaust valves, to disisapate heat more efficiently reside.) if the deformation was in that area, the exhaust stroke will reek the havok you see by a faulty seal. but iam sure HAM,INC, has a well reasoned explanation as to why i am full of shit and you need a set of new $2,000.00 heads. 6 You're a special kind of stupid aren't you. (IMG:style_emoticons/default/tooth.gif) Would you like me to count the the number mistakes and misinformation you've made in this thread alone? Because bud you've made plenty. You are nowhere near an expert on this subject, in fact you're a piss poor amateur. "nmeumonic exhaust valves" What? Are you saying nmeumonic is a material? (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 08:25 AM |
