Brakes are killing my leg....major pressure needed to stop the car. |
carcus |
Oct 26 2016, 09:55 PM
Member Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
Brakes sucked when I got the car, leaking caliper, bad master. Got all new wheel bearings, new rotors, pads, master. No leaks in the system. I have to mash the brake pedal down and it still takes lots of effort to stop. My last 914 was not like this. The mechanic adjusted them but think he forgot to check the pedal adjustment. Any tips to this? Am I missing something. This is about the brake pedal movement to stopping the car. Even at a red light I need to use alot of pressure to keep the car from rolling. The brake pedal should not have that much effort. Really makes the car not fun to drive. And there is really no bite to the calipers to slow it down if I have to slam on the brakes.
Cracker |
Oct 27 2016, 01:34 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
From the sound of it I believe you have a faulty MC...with a 17mm MC the pedal should be very compliant.
Tony |
carcus |
Oct 27 2016, 02:52 PM
From the sound of it I believe you have a faulty MC...with a 17mm MC the pedal should be very compliant. Tony The first one was faulty and leaking. This is another one I had to replace it. I would think 2 bad ones would be kinda rare. There are no visible leaks in the system and the fluid is full. Auto Atlanta mentioned it might be the flex lines. I have not replaced them. I am trying to send the first leaking master cylinder back to Auto Atlanta in exchange for some new flex lines. I will then have those replaced and the system bled again to see if issue is fixed. Auto Atlanta has always taken care of me in the past. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:09 PM |
