> CHT sensor extension, Curious, does it work? Who uses one?
malcolm2
post Oct 25 2016, 09:11 AM
I want to cover all my bases here. I have purchased the new GB CHT sensor from 914Rubber to try.
So, I think I will buy a spacer from Brad Mayeur to have the option. From what he says it should:
"Porsche 914/4 Cylinder Head Temperature Sensor Extension.
This little device slows down the heating of the sensor and improves warm up drivability.
I do have "warm up drivability" problems = Low idle RPM until the VDO CHT hits about 250*F. So it seems like my problems don't need the warm up to slow down, it needs to SPEED UP. (IMG:style_emoticons/default/WTF.gif)
914LTD.com
Also found on RATWELL (scroll down to WORKAROUNDS)http://www.ratwell.com/technical/TempSensorII.html#parts
timothy_nd28
post Oct 29 2016, 07:17 PM
malcolm2   CHT sensor extension   Oct 25 2016, 09:11 AM
bretth   If I understand it correctly it is meant to keep t...   Oct 25 2016, 09:22 AM
Mikey914   Exactly. I have one also and may reproduce these.   Oct 25 2016, 09:26 AM
BeatNavy   I do have "warm up drivability" problem...   Oct 25 2016, 09:28 AM
pbanders   The possible downside, which is probably attribut...   Oct 25 2016, 04:22 PM
BeatNavy   The possible downside, which is probably attribu...   Oct 25 2016, 05:39 PM
pbanders   [quote name='pbanders' post='2415735' date='Oct 2...   Oct 25 2016, 06:15 PM
malcolm2   I have checked what I understand to be the other c...   Oct 25 2016, 09:36 AM
BeatNavy   It doesn't slow down the engine warming. It s...   Oct 25 2016, 09:45 AM
pbanders   OK, I have one of these and have been using it for...   Oct 25 2016, 04:19 PM
malcolm2   From this and other research it seems that I may j...   Oct 25 2016, 06:52 PM
TX914   I wish some clever guru would create a way to modi...   Oct 26 2016, 06:13 AM
BeatNavy   I wish some clever guru would create a way to mod...   Oct 26 2016, 06:47 AM
Philip W.   i have dealt with same issue with my 2.0 d-jet tha...   Oct 26 2016, 07:15 AM
pbanders   i have dealt with same issue with my 2.0 d-jet th...   Oct 26 2016, 01:42 PM
Mikey914   Well a rheostat would give you the ability to have...   Oct 26 2016, 10:20 AM
pbanders   See my edited response above. BTW, it's nearl...   Oct 28 2016, 04:32 PM
BeatNavy   What worked best was to start with key off, then ...   Oct 28 2016, 04:46 PM
pbanders   What worked best was to start with key off, then...   Oct 28 2016, 05:59 PM
porsche913b_sp   I will have to keep you all's suggestions in m...   Oct 28 2016, 04:46 PM
pbanders   Here's the schematic for using a DPDT switch a...   Oct 28 2016, 06:02 PM
pbanders   I never was worth a crap as an EE, I was more of a...   Oct 28 2016, 06:06 PM
pbanders   OK, here's a circuit version with two pots, on...   Oct 28 2016, 06:35 PM
pbanders   OK, I can't stop, here's one more circuit ...   Oct 28 2016, 06:48 PM
Spoke   OK, I can't stop I know the feeling. Here...   Oct 28 2016, 08:37 PM
pbanders   [quote name='pbanders' post='2417044' date='Oct 2...   Oct 28 2016, 09:47 PM
pbanders   One thing I always know for sure: If I draw a circ...   Oct 28 2016, 09:52 PM
TX914   Very nice. This seems closer to being realized. I ...   Oct 29 2016, 08:19 AM
pbanders   Very nice. This seems closer to being realized. I...   Oct 29 2016, 05:35 PM
timothy_nd28   Instead of a switch, why not a small circuit that ...   Oct 29 2016, 09:02 AM
pbanders   Instead of a switch, why not a small circuit that...   Oct 29 2016, 05:36 PM
timothy_nd28   RE: CHT sensor extension   Oct 29 2016, 07:17 PM
TX914   I'll take 2 of those. :)   Oct 29 2016, 09:21 PM
pbanders   Tim, thanks, I've got all those components exc...   Oct 30 2016, 07:28 AM
timothy_nd28   Sorry, I know it wasn't helpful but I happen t...   Nov 1 2016, 11:28 PM
nine9three   I have the extension and it transformed my car whe...   Nov 2 2016, 11:07 AM
Mikey914   I have the extension and it transformed my car wh...   Nov 3 2016, 11:31 AM
porsche913b_sp   I have the extension and it transformed my car wh...   Nov 3 2016, 11:44 AM
Mikey914   What I'm getting at is you installed a new CHT...   Nov 3 2016, 11:55 AM
pbanders   I have the tester box all put together, not wired ...   Nov 3 2016, 11:24 PM
pbanders   OK, I got it all together and installed, and went ...   Nov 4 2016, 06:59 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:28 AM
